Stripped the thread...
[Closed] Stripped the threads in crank arm, any tips for getting it off?
[#2826407]
So the crank puller stripped the threads from the drive side arm and now i can't get the bugger off.
It's currently got a coating of WD40, and tonight it's going to get a good dose of the mallet and foul language. Unless you guys have any good tips for a more gentle way of removing it?
Matt
Posted : 07/06/2011 1:07 pm
Go riding, it will loosen of its own accord if you've removed the crank bolt.
Posted : 07/06/2011 1:11 pm
ride round for while it will soon fall off or use a rubber mallet & wooden drift
Posted : 07/06/2011 1:12 pm
Use a Ball joint Extractor and a mallet. Assuming it's square taper or the original hollowtech?
Posted : 07/06/2011 1:13 pm
Ball joint remover, a quick few smacks with the biggest hammer you have and it will fly off, Might damage the cranks in the process mind, although I wouldn't be refitting them if it was me.
Id use a bearing puller. Ball joint tools do basically the same job but a bit more agressive.
If the back side of the crank is rounded profile then a zip tie around the arms of the puller should stop them spreading.
Take a pic and we can point and laugh... sorry, advise 😉
Posted : 07/06/2011 1:20 pm
Hit it with a rubber/leather mallet a few times, it'll fly off.
If that doesnt work, move onto a normal metal one.
If that doesnt work, either escalate the effort or hammer size untill it does.
Just 'tickle' the arm with a hair dryer/hot air gun/blow torch. Quench the axle/BB/spindle at the same time. Gentle tap with a soft faced mallet. Job done.
Marko
Posted : 07/06/2011 1:21 pm
Cheers fellas, just looking at a selection of ball joint removers now!
They range from £160 for a fancy looking set of jaws to a few quid for a big 2 pronged fork - I know which one it will be!
Thanks for the advice, Mallet will be most upset!
Posted : 07/06/2011 1:54 pm
Had the same problem once, Resorted to a vice and a hacksaw to cut down the crank at the side of the BB axle, would not budge with a hammer. Was a cheap crank, luckily.
Posted : 07/06/2011 1:59 pm
Cheap and quick cut BB axle with Hacksaw drift out remainder with hammer and whatever is handy. If BB is shot that is..
Posted : 07/06/2011 2:02 pm
This, if you don't want the cranks. Doesn't take too long either.
Posted : 07/06/2011 2:07 pm
Just cut the crank. Saw down to the BB axle and it'll come off easily and if not, drive a chisel or similar down your cut. I'd have thought the BB axle is a lot tougher to cut than the crank.
The threads on the crank are stripped anyway, so I cannot see why you'd want to keep it.
Posted : 07/06/2011 2:08 pm
I've unscrewed the BB out from the frame and used the BB shell to take the crank off. Obviously, this only works on one side of the BB, AND relies on a well-greased BB.
Posted : 07/06/2011 3:51 pm
ball joint breaker puller. i used this method a few weeks ago. borrow one of a mate is the best way 🙂
Posted : 07/06/2011 4:02 pm
Take it to the LBS who can rethread it for you. Cost me £15 a couple of years ago. Cranks still going strong today.
Posted : 07/06/2011 5:34 pm
