Strava- not showing...
[Closed] Strava- not showing right times on leaderboard
on Strava, on some sections, in my fastest times it says All-Time PR 1:16 , but on the full leaderboard, I look up 1.16s, and it doesnt show me.
Also,on another trail, its Your PR 59s ,but beside that, it says This Effort, 55s.
etc etc
So why dont my best times show?
Are they auto updated, or do I have to do something?
Posted : 24/10/2017 7:00 pm
Accurate leaderboards are a premium feature*
*not actually.
Posted : 24/10/2017 7:14 pm
It sounds like you're taking it too seriously.
Posted : 24/10/2017 7:15 pm
On the segment page, click actions then "Refresh my results".
Posted : 24/10/2017 7:26 pm
Strava never lies..
Posted : 24/10/2017 7:28 pm
It takes a while to update the leaderboards.
and
Posted : 24/10/2017 7:37 pm
it was a while ago
craigW- I cant see actions/"Refresh my results" on my segments page
I was a premium member, but I suspect it only lasted one year. or one month
edit- found Actions- its on the this ride page.
Posted : 24/10/2017 7:50 pm
If your rides are private they won’t show on the leaderboard even though it gives you a PR
Posted : 24/10/2017 7:56 pm
so I refreshed but its made nod ifference
Posted : 24/10/2017 7:57 pm
*whispers* "it never has shown accurate times".
But... "Ssssssshhhhhhhhhhhhhh"...
Posted : 24/10/2017 8:12 pm
Try setting the ride to private, save it then undo private and save. Worked for me in the past.
Posted : 24/10/2017 8:18 pm
joonyboi- I'll check that thnx
Posted : 25/10/2017 10:14 am
[quote=gwurk ]*whispers* "it never has shown accurate times".
people only say that when strava tells them they are slower than they think they should be. but shhhhhhhh... 😉
Posted : 25/10/2017 10:22 am
You are looking at this years boards and your time was in the 'all time' board as it was in a prior year?
If this is correct can I get a KOT award?
Posted : 25/10/2017 10:26 am
my strava for my last ride told me my max speed had been 116kph. I run strava from an android app and I did drop my phone on a stop when out on the ride so I'm guessing that was the rate at which my phone hit the deck .. I'm sure I would have remembered 116kph otherwise.
Posted : 25/10/2017 10:45 am
I've just been through this with Strava support. If you have marked the ride as "Hide from Segment Leaderboards" then it's hidden from your own leaderboards as well as the public ones. This will give you the behaviour you are seeing.
On the right side where the segment leaderboard is listed along with your current position, that PR is the best time you've completed on a segment that's available to the public and not hidden from the leaderboard. The time on the left side is your time for the effort on the activity you are viewing.
If the activity is hidden from the leaderboard, you will still see all of the segments and your times for the efforts on them but they won't be posted to the segment leaderboard. If you edit the activity and uncheck the hide option then you will see your time show up on the segment leaderboard and also as your PR for that segment as well.
Posted : 25/10/2017 11:45 am
perditus
Pre Strava days my old phone registered 342mph during a crash (caused by picking up a branch through the front wheel) on iBikeRide. I'm pretty sure none of me was moving at that speed or I'd have been hurt 😆
Posted : 25/10/2017 12:01 pm
yes, I just made a few of my rides public, and it changed my leaderboard status
also cropped a couple of rides where I forgot to switch strava off before I drove off
Next question is how do I search for my best ever time on a section?
without meaking every ride public
Posted : 25/10/2017 12:02 pm
Sack it off and just enjoy the ride
Posted : 25/10/2017 12:06 pm
Use VeloViewer for all sorts of stats and analyses.
Posted : 25/10/2017 12:09 pm
Next question is how do I search for my best ever time on a section?without meaking every ride public
Find a ride with the section/segment you want to look at and open the ride. Click on the segment, you'll get a panel showing lots of info about the segment. At the righthand side is the leaderboard. Click on "Show full leaderboard". In the new screen there's a graph showing your efforts on that segment which will include your PR. This works regardless of the ride being public/private.
But, as Scotroutes says, VeloViewer has loads of stats about your rides. For £10 a year it's much better value than Strava premium.
Posted : 25/10/2017 12:36 pm
