Strava GPX onto Gar...
[Closed] Strava GPX onto Garmin 800 - Any work around yet?
[#5486449]
i know they turned off the API job that allowed conversions
any work around?
Posted : 04/09/2013 10:21 pm
Strava Premium
Posted : 04/09/2013 10:26 pm
I'm assuming you want to load the file on as a route for you to follow. If so then when the Garmin is connected to your machine drop, the GPX into the New Files directory (the Garmin should show up as a drive on your computer while plugged in). Next time you start the Garmin the track will be there as a route.
Dan
Posted : 04/09/2013 10:27 pm
i have premium, i can download the GPX
however when i paste into new files it doesnt appear on the 800
Posted : 04/09/2013 10:30 pm
try using something like [url= http://www.gpsies.com/convert.do?language=en ]www.gpsies.com[/url] to convert the file you downloaded to a TCX then drag it into the folder on the 800
Posted : 04/09/2013 10:46 pm
cheers ill try that
Posted : 04/09/2013 11:14 pm
If that doesn't work then try loading it into bikehike.co.uk then saving it to the Garmin.
Posted : 04/09/2013 11:23 pm
^^^this is what I do^^^
Posted : 05/09/2013 8:41 am
tcx conversion on gpsies worked
cheers
Posted : 10/09/2013 11:38 pm
