Strange sound
[Closed] Strange sound
[#881417]
So, left the house today cycling to my local trails. After a couple of hundred yards I could hear a strange sound. The best way to describe it would be as though you were holding two spokes (that aren't attached to a wheel!) and gently tapping them together.
I stopped, thinking I'd snapped a spoke, and checked both wheels. Both running true and the tension in all the spokes is fine. I checked the brakes for the pads rubbing but nothing there.
It's very intermittent and continued through the ride. Just a "tss tss tss" sound as though someone was touching two long,thin bits of metal together.
Any thoughts?
Posted : 19/09/2009 8:33 pm
I know you checked the brakes, but it sounds like the spring clip thats between the pads.
Posted : 19/09/2009 8:44 pm
gear cables knocking against cranks or wheel spokes?
Posted : 19/09/2009 8:46 pm
Ah.
Avid Juicy Threes with that little spring clip thing and they are in need of a pad change soon. Probably less then 1mm on one of the pads.
Is that the likely source then?
crickets or grasshoppers
Seriously!
Posted : 19/09/2009 8:47 pm
I was on a city road when i first noticed it so no crickets or grasshoppers
Posted : 19/09/2009 8:48 pm
