Straightening dinge...
[Closed] Straightening dinged rims - Does anyone make a specific tool?
Just been looking at the Pinkbike tech tuesday guide to straightening rims:
http://www.pinkbike.com/news/Tech-Tuesday-Fixing-Rim-Dents-2012.html
Really like the look of the Morningstar Rim 'Rench, but it seems they're not made anymore since Paul Morningstar died.
http://www.bikeradar.com/gear/category/tools/cycling-tools/product/review-morningstar-tools-rim-rench-11-45426/
http://morningstartools.com/
So, has anyone copied the Rim 'Rench?
Posted : 04/03/2015 2:30 pm
If you can get some accurate dimensions of a Rim Rench,I could make one for you. ๐Ÿ˜‰
Posted : 04/03/2015 2:36 pm
It was a long time ago...
...but last time I needed to do this I just stuck two foam sticky pads to an adjustable spanner, tightened it up and levered the rim back to where it should be.
It was a brand new Mavic F519 which I dented on its first ride. I came up short on a huck to downslope over a footpath. The footpath had a raised edging which I caught. Was not happy!
*edit* just clicked the link and saw they too used an adjustable spanner. I still recommend the foam sticky bits though.
I've always managed with a big adjustable spanner.
Posted : 04/03/2015 2:41 pm
Blimey, found how Paul Morningstar died:
http://reviews.mtbr.com/toolmaker-paul-morningstar-found-dead-in-booby-trapped-california-home#slider-pro-2-2
And a DIY copy:
http://forums.mtbr.com/tooltime/inward-rim-dent-puller-diy-949450.html
Be good to find the original though to get the dims from it. fasthaggis, fancy making up a few versions to develop it?
Posted : 04/03/2015 4:14 pm
Humungous aj and a vice are the ideal tools surely?
PS, relieved to discover you can search google images for rim rench and not get sacked.
Posted : 04/03/2015 4:27 pm
Whereas "rim wench" might have different consequences, but I'm not going to test that one.
Posted : 04/03/2015 4:29 pm
 nuke
Never heard on them before but now I want a Rim Rench more than any tool ever in the whole history of the world ๐Ÿ™
...might try and make one
Posted : 04/03/2015 4:40 pm
Fasthaggis, I may be able to help.
Is your e-mail still the one in your profile?
Posted : 04/03/2015 6:12 pm
a wide-jawed adjustable spanner is better than any "specific" tool, as its wide enough to spread the pressure and not crease the rim wall.
Posted : 04/03/2015 8:04 pm
Been using a modified adjustable for years, ground back the tip that fits inside the rim as it needs to be a shallower depth, and rounded the edge that sits on the outside of the rim so it doesn't dig in.
Posted : 04/03/2015 8:05 pm
Adjusti spanner and a flat bit of metal held against the outside works perfectly
Posted : 04/03/2015 8:06 pm
As above ^
Video showing what a piece of piss it is.
Posted : 04/03/2015 9:29 pm
fasthaggis, fancy making up [s]a few versions to develop it[/s] one for me?
FTFY ,I don't do mass production,the workshop minions* would get annoyed.
* [i]they are too valuable to annoy[/i] ๐Ÿ˜‰
@Velo
If you have dimensions or a DXF/CAD file that would be useful.
Posted : 05/03/2015 11:49 am
I followed the Pinkbike guide in the past with the standard wrench and a flat bit of metal, and worked perfectly. I wouldn't bother with a dedicated tool myself.
Posted : 05/03/2015 12:43 pm
I was going to suggest a hammer and a bit of wood, but the adjustable spanner method seems a little more refined. ๐Ÿ˜‰
Posted : 05/03/2015 1:16 pm
Yep always use an adjustable spanner.
Posted : 05/03/2015 1:52 pm
Fasthaggis, can't do a DXF/CAD and dimensions are a bit tricky because of the shape, but would a pdf containing a to scale scanned "copy", with a couple of rulers beside it to confirm the scale, be of any use?
Posted : 05/03/2015 8:02 pm
That's a good idea.
Using an adjustable is sort of OK, but it does create a sharp dent or 'fold' in the rim wall in the middle (on the outside). There is definitely an (admittedly niche!) market for these tools.
Posted : 05/03/2015 8:12 pm
If you hit it in just the right place it [i]should[/i] pop right out.
Posted : 05/03/2015 8:29 pm
Use one of Sheldon Browns dent removers, see:
http://sheldonbrown.com/dent-removal.html
Posted : 06/03/2015 11:08 am
I use a mole grip that has a hook/lip on the grip in just the right place to lever out the bead against the right area of the outside of the rim- set the width, protect the rim and go easy. With old-generation P35s and 18psi tyres you learn to pull out dings effectively .. but a proper tool would be a good call, I'd be buying.
Posted : 06/03/2015 1:54 pm
