Just got a branch caught in my rear mech. At a first glance it appears I may have got away with just bending the slidey dropout (looks about 7mm steel, orange p7)
Im out for a ride tomorrow, how accurate does it need to be, if I put it on the vice anvil and tap it flat with the universal adjuster is it likely to be good enough? Precision is not my middle name.
that should be enough as long as the mount is straight.
tbh, as long as the gears change ok then it's ok.
bear in mind it will be weaker now. Might be worth carrying a spare hanger or getting one of those emergency ones if it'll fit?
I've had passable results in the past using the "bash it with a rock until it looks straight" approach.
That said, I'm a mechanical disaster area generally, so hopefully better advice will be along in a minute.
Lining up by sight works for me, I couldn't say what that tolerance is.
IMO an adjustsble is a good tool. 7mm steel is thick/strong though! Usually sliding dropouts are aluminium.
If its not right, the gears may still shift right but you can put the chain into the spokes.
Ah shite you're right, its ally. Oh well, i'll give it a go but order a new one I think.
They rarely break on straightening IME
Order a new one. Tried sorting one out just the other week and it just wasn't right. Gear shifting was crap.
Tried to straighten mine in a vice......it'll get you by, but it's not "right". Bought a new one.
Well ever the optimist i'll give it a go. Thanks all.
They wont fix it?
Sure is thin around the mech hole thing.
If its steel and integral to the frame get it to an LBS and get it aligned PROPERLY otherwise it will be a total pig to set up indexing.
If its a replaceable one then just replace it, its sacrificial component and its done its job. We had a nightmare job with a customers new bike that would drop its gear indexing after 30 miles without fail, turns out he'd dropped it in the garage and it had bent the hanger, he'd straightened it but omitted to tell us that wee fact (it was just out and no more) but as it had been bent what would happen is that it would flex with use thus the indexing would go. Replaced the hanger end of problem.
I've had some success with sorting out slightly bent ones by (with rear mech on) putting an Allen key in the attaching bolt and using it as a bit of a lever while pushing the hanger back. Slight chance of knackering the rear mech though I guess so I've only ever done it when out on a ride. I'd just buy a new one otherwise.
cynic-al - MemberThey wont fix it?
Offered to try and get me a new drop out but wouldn't repair it. I tried to then get the drop out and no reply.
Yup, very thin isn't it. Too thin.
Had a repair quote from Enigma which was viable.
