Any more info and pics of titanium version please Andy?
i chose this system because of it's foolproof simplicity. In the past i've had various types of ebb. all of which creaked terribly or were a bind to adjust. Worth mentioning that the BB shell is machined after welding to ensure a perfect fit. Also worth mentioning that the bolts only need to be tightened to 4nm, which isn't very tight at all. The bolts are also flat-headed to prevent the gouging that can be a problem with the pinpoint bolts some companies use. If you don't overtighten you won't have a problem. The frames come with plentiful amounts of coppergrease in the shell, so far no problems at all. Hope that helps.
Thanks for chiming in, I've had various ebb's as well from a Bushnell expanding wedge to split shells, which have been trouble free in my limited time with them, are there any negatives associated with split shells that perhaps I'm not aware of?
no problems at all with split=shell, providing the tolerances are correct and you grease and don't overtighten the bolts. Having said that, i've not used one and i can see that an opening and closing clamp isn't ideal when you think of the welds in that area.
re ti frames, as soon as i have them i'll be posting photos up. About a month away at the moment.
colours - don't really want to spoil the surprise just yet
I've been using a grub screw ebb for nearly nine years now on my off road commuter, it's never given me any problems in that time. It would be my first choice if I were looking for another frame.
I think I'm going to find the Ti Stooge hard to resist but in reality I think the single size is probably just a bit to big for me.
How tall are you?
bear in mind the shortest rider to buy a Stooge is 5'4 and she has no problems with sizing. I know it goes against everything we think we know, but it really does shrink and grow very easily. The standover is the same as a 15" bike, but the front triangle is longer and taller. come and have a ride on one.
From what I've read the Stooge is a very capable descender however I do quite a bit of sustained climbling before going down hill, for all those who have the Stooge is it a capable climber as well or is climbing a bit more difficult because of the slack angles? I plan on running it single speed with a Maxxis Chronicle.
Climbs fine. It's not a race bike but it is a nice solid platform (mine is ss).
Agree. Actually really good technical climber. You can move around allot on the bike, it feels like it has a low centre of gravity, combined with big grippy tyres its very capable. Lighter wheel set made a difference for me on longer days with lots of climbing. Maxi Chronicle up front is perfect IMHO.
What did you go for?
Whats your back tyre Mr Guitar Hero?
It's a Minion DHR2 2.3, I'm currently rather fond of it. Got a nice profile on the 50mm Nextie rim
Hey Guitarhero, whats the clearance in the rear look like with those Minions on wide rims, ie:chainstay and seatstay clearance? Do you have any pics? Curious to know if those tires are wider and taller than the Ikon 2.35ยจ when mounted on such a wide rim.
what would happen if you put FS on it?
There's a little more clearance than the 2.35 Ikon on a flow EX rim.
Quirrel - Member
I'm curious about this.
Andy says that the availability of straight-steerer forks is the main issue, although it's also explicitly a rigid-fork design and it looks like it'd be hard to match the rigid fork's trail with an off-the-shelf bouncy version...?
Not for me. It's designed as a rigid bike. If you want to use sus forks buy something designed to work with them?
Wide lightnings. Rear pick up isn't quite up there with Hopes, but (touch wood) fine over the winter. Nice light, wide enough, stiff and resilient enough, work well tubeless, ( I ride steps/rocky stuff routinely).
Thought it looked bigger than my rear, which is a DHR on a p35. Great tyre and yes you have even less clearance than me. Its good to know it fits as I have an idea...
Well I've just built myself a Stooge, had 1 ride on it and it's great. The last rigid bike I rode was my 1996 Kona Lava Dome, this is better! I wanted to be able to ride this all day and was a bit worried it would be too much of a hooligan, it is a hooligan, but could still put in long days. Climbing is pretty good because you can really move your weight around to find traction. [IMG]
[/IMG]
Excuse the taped on brake hose, I've used left over bits and the hose is too short, I might swap the bars to something with more sweep. Frame was 2.9kg and built with carbon wheels and 1x10 it's 12kg.
One 'ride' is usually all of a legover conversion you need to for a Stooge ๐
And you've got lots of enjoyment to come on that bike from ride number 2 on... ๐
re suspension forks, the bike is designed for rigid forks and as such it would be pretty hard to find a pair that would preserve th geometry, the great thing about rigid bikes is that the geometry doesn't alter at all and once you dial into that you can really become one with the way it handles. Secondly, most suspension corrected frames will have downtube clearance, this doesn't. Having said all this, one of my customers fitted a pair of Reba's with a longer lower headset cup and reports that it works very well.
The Stooge geometry is designed for slightly larger diameter front wheel, ie 29+. The rear is designed for a 29 x 2.3 rear tyre, 27.5 x 2.8 also fit, both of which will preserve the geometry. regular 29er tyres will work front and back but the handling sharpens up a little, though not in a bad way at all.
Out of interest what color EBB do people have in there Purple frames? Mine came blue, but in the pics the rest look silver?
Trying to decide on a rear tyre to fit
It'll be on for a while, so fingers crossed dry and fast
Any suggestions
On my original build I used a 2.4 X-King on the front and a 2.2 out back, worked well and the bike lived up to my expections.
Then I fitted a Dually and Chronicle up front. It does change the ride and actually lets you do some pretty stupid things. My biggest issue is bars, the Stooge has turned me into a compulsive bar swapper, there's nothing wrong with any I've fitted but I'm always convinced the next pair will be that little bit better. At the moment I've got flipped On-One OG bars on there ... don't worry, I've apologised to Andy for it already. ๐
The wider front rim made a appreciable difference for me too (with Chronicle)
Any other suggestions for a rear?
Are any other owners having trouble with a slipping seatpost? Mine won't stay put with a QR so I've had to go with an Allen bolt collar.
It's definitely my favourite bike, and a keeper (until the Ti one comes along obviously)
No issue here. What post is it?
I've used a Thompson lay back and currently a Kent E ti - both were fine
Mine slipped a bit with my Gravity Dropper and a cheap oem clamp but today I used a Surly constrictor clamp and no issues so far
No seatpost problems here with a Twelfty and an RSP dropper.
Stooge rides best with a 51mm offset 100-120mm suspension fork. Its fab 29+ but metal with boing. See the stooge facebook or one cog facebook for pics.
Mine slips with a Thompson and a qr done up very tight, might switch to carbon paste. I blame the Thompson post!
titanium Stooge frames should be landing next week, photos to follow
^ ๐
Popcorn
BTW Bonesetter, not normally a supporter of the big S, but the Specialized Slaughter is a great rear tyre.
Thanks Mr S ๐
I'll give that a look
Excited! Have you got a price and spec on the frame?
they're sitting in customs at the moment, as soon as i know how much they're going to charge i'll be able to work out a price. And as soon as i get them i'll be posting photos. But in a nutshell, 44mm headtube, bigger downtube, slightly bigger top tubes, more tyre clearance, should be a bit of a beast.
^ ๐
If anyone is interested in a blue frameset, I'm looking to move mine on.
900!
