A long post sorry! I am signed up for the 5-12 Oct week. Going solo so getting the fear on how tricky this is going to be. So this message is either going to make that worse or help .....
My current bike is not ideal for this trip, Santa Cruz 5010 with 27.5 wheels. Running a 150mm fork (fox 36). Trying to find a suitable second hand 27.5 compatible enduro frame but they are not going cheap. If I cannot find one I will plan to put offset bushings and maybe up the fork to 160mm.ย I have done Alps trips with this and similar bikes but not sure how under equipped I will be for this. Riding blind and with higher fatigue than normal makes me worried!
For tyres I plan to go for Maxxis DD at the rear and probably EXO+ at the front. Probably no inserts as I don't want to risk having to carry one around if I needed to use a tube.
Plan on brake bleed, new linkage bearings and front/rear suspension service a month or so before. Pedals, hubs will all be checked as well. Anything else? Dropper service?
Kicked off the training but think I am going to struggle to get more than 15hrs a week by mid September.ย I hoping that will be 130-150k with 3000-4000m vertical a week. Is that enough or am I going to struggle. It is definitely not the full distance but not sure how I can get much closer.
On training, is doing a 1hr ride before work and then another 1hr at lunch a waste of time or will it work given the breaks in the actual event for shuttles?
Any ideas on exercise to help with arm pump and fatigue? I am worried about that!
Given I live on the south downs, technical riding training is going to be a challenge. But going to have to fit that in somehow!
For those who have done it, how bad is the hike a bike?
get used to carrying your bike, maybe spend the lunchtime hour going up down a hill three times a week, you might get some strange looks though .....
Thanks for the comments. Listening to the pod cast now. The guys doing the proper race are pushing hard. I hope the tour will be a bit more relaxed.
Tempted by one of these for carrying
https://pushcomponents.com/produkt/hookabike/?lang=en
I'm doing it the week before you.
I've not ridden SKR, but I've worked on it and Transprovence since 2014, so I've plenty of allied experience.
The bike will be fine. There's such a variety of trails. Some might might be hard work, others a shorter lighter bike will be better for. You'll also be burying yourself less on the uphills on a lighter bike so will be fresher for the descents. (one of the course markout guys, who rides the route a day or 2 in advance of the race, rides a Stanton Ti hardtail). Tough tyres and rims, the biggest brakes you can fit and some kind of bash/sumpguard will be the way forward, plus well setup and looked after suspension. You're not racing, and it is a holiday so you won't "need" to dish out the same kind of abuse that the racers do because "race".
(I'll be taking my 29" Rocket Max and am expecting to be fighting it on some of the flatter traversey stuff, but it'll monster the steeper rougher sections)
I believe the club weeks are a bit less arduous than the race - there's more options for shuttles when you only have to get 1 vehicle to a location, not 20. When I did the equivalent TP tour week in 2014, I was actually slightly surprised how little climbing there was, but its a bit of a different thing now.
Its less of a problem in Sept, but take a floppy hat for the big climbs out in the open - not getting fried to a crisp is a good thing. Eat and drink plenty (food availability isn't usually a problem - just make full use of it).
Training wise - all riding is good riding, but I'd be aiming to do a good few full day, proper long time in the saddle efforts - 7 or 8 hrs plus. Mental toughness is a large part of it - the fittest I've been is when I was doing a gym session the other side of town with 350m of climbing in the commute. Riding home from it after a heavy weights session was just hideous, but it got easier, and in comparison nothing outside of that felt near as hard.
(there's always a rider or 2 in the races who struggle/pull out because they crack mentally. Equally there's always 1 or 2 who suffer like a dog physically, but you know they'll finish because they've got a bombproof head game)
Arm pump. Gym stuff/core work/pressups; (indoor) climbing/bouldering; uplift days; w*nk more; big brakes; don't carry excess weight around on yourself. Just riding lots will help too.
Hike a bike. Ash is a bastard for that. But it never fails to be worth it. No one enjoys it, its never easy, you just have to crack on and get it done. Can you spend some time up in the Lakes before hand - do a lap of The 4 Passes and/or whip up Hellvellyn? mostly its just a question of knowing how to carry the bike least uncomfortably.
What JonEdwards says....
For the original Trans Provence in 2009, Ash suggested robust hardtails. I've never been so beaten up on a bike in my life ๐ What you have now will be great, so don't overthink it.
The hike-a-bikes can be quite physical, so get used to carrying weight up hills and while there are uplifts, there certainly used to be plenty of climbing during the course of a day (updulations I think is the correct term ๐ )
Regular back to back rides, twice a day rides etc will all help but factor in some long days in the saddle.
I haven't done the SK, but did a shorter multi-day in the Alps last year (with bigger days).
What I'd say is:
- Make sure you're conditioned to long days on the bike - in terms of stamina, carrying and resilience to saddle sores.
- Do use inserts, with tough tyres you'll be very unlucky to hole one beyond repair.
- +1 to Jon's suggestion of big Lakes days, maybe Scotland too.
- +1 to eat and drink more than you might think you need to.
I did this last Sept for my 50th birthday present to myself. It was the best biking holiday I've been on. Absolutely amazing trails, really really well organised and great company. Met lots of new friends from around the globe. For me, I'm not satisfied with a biking holiday unless I'm knackered at the end of each day! And this one provided! There are plenty of uplifts, but of course and as you know, there is a shed load of climbing too.
The first day for example you will climb 5000ft in 18miles - thats just the morning! Afternoon however is all DH ๐
The third day had I reckon the toughest climb - 3600ft straight up, in less than 6miles. Took forever and 60% was hike a bike.
But the descents! The descents were sheer joy! You get all the different types of terrain. Alpine meadow, loose rock, forest pine, and dust+slabs nearer the coast.
The food was varied and the amount of courses varied a lot too. But all good. Accom was a mix of hotel and apartments. Oh man, I wish I was back there!
I did just a couple of longer rides for prep, but then I consider myself fit doing lots of workouts a week. I would say the majority of people on the tour were less fit and everyone managed it just fine. There were no escape routes taken by anyone. If you can handle a 30-40mile South Downs ride with no fitness issues and could do that daily for a week, you'll be good. You have the whole day to do these rides.
As for mechanicals - believe it or not, there wasnt a single puncture in our group! No major mechanicals either, just the odd broken spoke. I ran EXO+ front and back, which I usually ride in Alps. Went through 2 sets of Galfer pads on rear (purple I think).
That podcast just scares you. Leading up to my trip I was listening to that and it was sounding like I wasnt prepared enough. But speaking to the guys out there, the chap on podcast is a bit of a worrier, and you shouldnt read too much into it.
Here a load of pics
https://i.ibb.co/4R1Pxfs/IMG20230926155542.jpg
https://i.ibb.co/wCXNZqB/IMG20230927162024.jpg
https://i.ibb.co/9g5YMXx/IMG20230927162436.jpg
https://i.ibb.co/3vvJ76R/IMG20230928140416-2.jpg
https://i.ibb.co/8MnVctH/IMG20230929194302-2.jpg
https://i.ibb.co/19RZ0TY/IMG20230926152841.jpg
https://i.ibb.co/PTPJ6yV/D3-EE900-A-8085-493-E-8-D23-FBCB7-F7-BCF11.jpg
https://i.ibb.co/yQsTxSr/IMG-20230928-WA0009.jpg
https://i.ibb.co/fDcx1bS/IMG-20230929-WA0027.jpg
https://i.ibb.co/Vp03MQB/IMG20230924105044.jpg
https://i.ibb.co/d6KNDNc/IMG20230924155441.jp g" alt="" />
Day3 afternoon climb of hell, Descent of bliss!
Looks absolutely mint. One for the bucket list for sure.
I'd need to prepare for it though, I'd be dead after 2 days.
Really good stuff. Sounds like the bike might be ok.
Doing daily rides over 2hrs is going to be tricky. With work and family it is just not going to happen. Will try and get to some roper hills though!
Following with interest for a potential 2025 trip. I also have a 650b 5010, so keen to know how it holds up.
I just hope the bike and me survive! Still tempted to get something with more travel if I can find one.
Superfli the photos look great. Question on the hike a bikes. Are they sustained hikes or on off walk pedal walk etc? Just wondering if I should think about the hookabike thing or fashion some kind of pad for the bike to go over my shoulders.
The hike a bikes were all, except a tiny bit, pushing the bike. You won't need anything to carry the bike. Mainly long spells of pushing, rather than on off. Sustained steep or just too steep to make the peddling effort. Saying that, the chap we were riding with was 7 times US national single speed champ. He did like a climb lol!
