Over 4 weeks later I am still looking for a bloody hub conversion kit !
I want to change by standard front 240's 6 bolt disc hub to take the DT Swiss RWS Thru bolt - My hub is one of the ealier ones that will not take the 15mm or 20mm bolts
Kimbers - you replied on a thread that you had done this - with a part from Jenson - My LBS cannot seem to get hold of one and are now telling me they don't think the part exists !
Can you confirm that you managed to do this - I have the RWS thru axle but can't source the hub converter
thanks
p.s Kimber would have emailed you but you don't have a visible email address
sorry i did this with a hope pro II not a dt240
i have however got the workshop here to drill out some qr adapters for my pro IIs
but they screwed it up as the pillar drill was out of alignment then hope went and released some so i bought em anyway
assuming that the thru axle will fit through the middle of your hub?
can you drill out your dtswiss endcaps, are they even removable??
if so just make sure it is perfectly lined up!
ah - thanks mate
anyone else converted a 240 hub to DT's bolt thru ?
