Stiffening up my re...
[Closed] Stiffening up my rear triangle
[#2606740]
I'm running QR's with a Shimano FH-M475 rear hub. Is it possible for me to buy adaptors to run a solid rear axle ?
Posted : 28/03/2011 3:34 pm
You could convert it to a bolt up (solid) axle easily enough though you'll need to take a 15mm spanner with you in case you need to change a tube...
Posted : 28/03/2011 3:39 pm
I was thinking of something like [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=31831 ]this [/url]
Posted : 28/03/2011 3:57 pm
A wheel built on a Hope BigUn with a d521 will do nicely.
Posted : 28/03/2011 4:00 pm
Doubt it's gonna make significant difference.
Posted : 28/03/2011 4:01 pm
That won't work btw. you need a threaded axle.
Posted : 28/03/2011 4:17 pm
A properly stiff wheel won't work? Gotta disagree with you mate on this one. His hub isn't rigid enough, the rim probably lacks rigidity too.
Posted : 28/03/2011 11:12 pm
No, his suggested axle won't fit his hub.
If he wants a stiffer wheel then you may be right, he wanted to stiffen his rear triangle though.
Posted : 29/03/2011 11:58 am
why?
Posted : 29/03/2011 12:26 pm
As much as I hate to agree with Al (twice....it pains me so) that 10mm qr won't fit and I don't have the pre-requisite patience to explain why.Put a nutted axle in it.
In terms of stiffness it makes bugger all difference unless its a proper pinch bolted dropout design (that goes for maxle and 142X aswell).However having your wheels held on by a 4mm piece of steel rod and 50 year old designed cam fills me with dread.Its just a more secure way of attaching wheels to a bike.
Posted : 29/03/2011 12:33 pm
He'd need to fit a Superstar or Hope 10mm rear hub to use that 10mm QR.
I've got a Hope 10mm rear wheel with a Superstar 10mm QR which seemed to be stiffer than a regular QR.
Also Fireeye do a cheap 10mm QR - almost 1/3 of the price of the NC17 ones - http://www.chainreactioncycles.com/Models.aspx?ModelID=39202
Posted : 29/03/2011 12:50 pm
Rosarch, does it pain you to concede that your prejudices about me are wrong? 😛
Works for many milions of riders, including gnarly types.
TT, not sure what your question is.
Posted : 29/03/2011 5:31 pm
I can do you a nice line of Bigun's on D321's - indestructawheels. 😉
Posted : 29/03/2011 5:36 pm
i found a 10mm thru qr axel like the nc17 one or the burlier superstar ones do stiffen up the rear of multi linkage bikes, noticeable when landing jumps and drops at squiffy angles
you will need a new wheel with a compatible hub
or try one of these
no experience with them myself and pricey...
[url= http://www.stif.co.uk/mtb/product/dt-rws-wheel-skewers/7206 ]http://www.stif.co.uk/mtb/product/dt-rws-wheel-skewers/7206[/url]
Posted : 29/03/2011 5:43 pm
All food for thought, thanks. On reflection I think I'll stop worrying and ride my bike as it is.
Posted : 29/03/2011 7:01 pm
on some suspension bikes it can make a huge difference. Do mountain bikes need QRs?
Posted : 29/03/2011 7:04 pm
@one_happy_hippy: sorry to hijack but what length of spokes for the rear? Can't work it out. Thanks!
Posted : 30/03/2011 9:58 am
 GW
have you tried lifting drink bottles? 😉
Posted : 30/03/2011 10:01 am
