Sticky lever - hope...
[Closed] Sticky lever - hope mono mini
[#3668704]
One of the levers doesn't always return properly, and leaves the brake dragging. It's on my girlfriends bike and she nearly passed out going up a hill last week because she didn't realise the back brake was half on!
I'm normally happy fixing mechanical things, but if it's a piston seal in the lever body, would it be best to send it back to Hope?
Posted : 12/02/2012 11:49 am
Try the lever pivot bolt for being too tight / sticky or the brass bush in the lever.
Posted : 12/02/2012 12:05 pm
Thanks. The pivot bolt is fine, as is the little brass thing that connects the piston to the lever. It feels as if it's the piston itself.
Posted : 12/02/2012 12:18 pm
Simple enough to do if fiddly - could be the spring in there or the seal - youneed small circlip pliers to do the strip tho - I have done a lever once - it wasn't difficult
Posted : 12/02/2012 12:20 pm
