Stem Help, an Ideas
[Closed] Stem Help, an Ideas
5 Users
I'm searching for a new stem to move my position around a bit on my Scandal
At the moment I've got an 80mm @ 5-6 degrees I think, with a Fleegle bar (flat with 15 degree sweep)
I'm after a stem to bring me back and up a little!
'cos of a bit of a lower back strain on long rides 6+ hours, climbs especially
I was trying to find a 65 or 70mm (don't want to go too short) with about a 15 degree rise for non oversized bars. (I know more rise alone will effectively bring me back a little)
No options to move the Stem up the steerer, it's at the top already
I like the sweep on the bars I've got 15 degrees I think
Any ideas? I've not been able to find much thats not some massive chunk of square billit alloy designed for DH Dutys (all oversize anyway)
I have thought about a OS Salsa ProMoto (or similar) bar with the same sweep
this will bring me back 'cos it doesn't have the fleegle forward backward sweep thing going on but does nowt to move me up with out a new stem too and still struggling to find any no OS stems with 15odd degrees
hoping to find a stem only option as opposed to stem and new bars too
Any ideas Chaps & and Chapesses?
Posted : 11/02/2010 1:17 pm
What's up with a riser bar?
Posted : 11/02/2010 1:30 pm
I had thought that, but are there any about with that sort of sweep on 'em?
Posted : 11/02/2010 2:12 pm
I use [url= http://www.bikeradar.com/gear/category/components/stem/product/comp-road-stem-31001 ]This[/url]
Lots of adjustment
Posted : 11/02/2010 2:19 pm
most are over sized too
may have to be Stem and Handlebars to get where I want to get to.
was hoping to save some ££, bit skint at the Mo
and only a bit of an experiment really too
all I want is a Stem at 70mm with 15Degrees and a 24.whatever it is mm clamp 😥
Posted : 11/02/2010 2:22 pm
Cheers Dales_Rider, used one when I got my Niner set up recently
very useful
but unfortunately only goes down to 75mm hoping to go a bit shorter than that ideally
Posted : 11/02/2010 2:25 pm
Seems 15 deg tough to find, can't you shim this out?...
20 deg: http://www.chainreactioncycles.com/Models.aspx?ModelID=28647
Posted : 11/02/2010 3:02 pm
 br
move your seat forward?
Posted : 11/02/2010 3:04 pm
cynic-al, yep could use a 70mm 20D but it's over size so need new bars too
which I was hoping to avoid
b r, could do but doesn't get me the rise I was after
looks like I'm after the moon on a stick 😥
Posted : 11/02/2010 6:11 pm
