Stem bolts ..how ti...
[Closed] Stem bolts ..how tight?
12 Users
The intraweb suggests that 5nm is what's needed.
Thought I'd check how tight I tighten my bolts to. It's 8nm , is that too tight?
Tried tightening to 5nm but I could still twist my bars.
Posted : 20/02/2022 6:18 pm
What do the manufacturers of your bars and stem say?
Posted : 20/02/2022 6:23 pm
All mine seem to be 5 or 6nm.
Posted : 20/02/2022 6:25 pm
5mm is pretty standard with stems with M5 bolts, stems with M6 bolts usually a bit higher, I've seen 8nm stated on some old stems, if my bars were carbon I'd be sceptical about going that high though. Find a similar spec stem to yours and look up that stems torque settings if you can't find them for your stem.
Posted : 20/02/2022 6:32 pm
Hope AM stem is 6-7Nm
Posted : 20/02/2022 6:34 pm
All my stems with m5 bolts using a 4mm allen key say 5nm for the face plate, an old truvativ stem I've got with m6 bolts says max 6.8nm.
Posted : 20/02/2022 7:03 pm
Is your torque wrench accurate at those low levels? 5nm should be plenty to hold the bars in place.  I bet mine are not even that tight
Posted : 20/02/2022 7:07 pm
It depends, my Thomson one is about 4nm whereas my RaceFace one says up to 9nm. I use friction paste so less torque is needed.
Ideally you tighten as little as possible for it to do its job
Posted : 20/02/2022 7:14 pm
TJ ,I've got one of these
https://www.superstarcomponents.com/en/reviews/12864/
Posted : 20/02/2022 7:22 pm
Hmmm - no name torque wrench .    I wouldn't trust it to be accurate enough.  Maybe my bias against the seller showing of course but 5nm should be plenty tight enough for stem faceplate bolts IMO
I would forget the torque wrench and do them up with a standard allen key  just a tweak past finger tight using the long end
Posted : 20/02/2022 8:02 pm
I alway do mine up 6nm
Posted : 20/02/2022 8:08 pm
Something is seriously wrong if you can move your bar at 5Nm, unless you are rocking Ape Hangers!
Posted : 20/02/2022 8:16 pm
It's all nonsense without knowing the size of the fastener - 5Nm on an M5 =/ 5Nm on a M6. Are the threads greased or loctited?
A M6, ungreased bolt at 5Nm could exert less than half the load of an M4 that's been greased at 5Nm.
Torque it to the manufacturer spec, and assemble it with/without grease as they tell you.
Posted : 20/02/2022 9:42 pm
I had carbon bars turn in a Thomson stem I torqued up using a bontrager 5nm dedicated doodah (bought for carbon seat post when I dabbled as roadie scum). Which is why I sold the bars...
Only 10mm risers too...
Never had problems using the same thing on Hope stems I’ve on pretty much everything now... but with alu bars I don’t mind a little extra tighten if it doesn’t feel up to snuff...
Posted : 20/02/2022 9:43 pm
