Steel Hardtail with...
[Closed] Steel Hardtail with 12mm bolt through
Got a mate looking for one....
.....anyone know if one exists?
Cheers,
Mark
Posted : 04/02/2015 9:38 am
The Niner ROS 9 does and its purple!
Posted : 04/02/2015 9:41 am
PP Shan has it as an option
Posted : 04/02/2015 10:20 am
Stanton switchback.
Posted : 04/02/2015 11:09 am
Yes, this:
2Souls Quarterhorse.
Posted : 04/02/2015 11:11 am
El mariachi has the option.
Posted : 04/02/2015 11:28 am
http://www.btr-fabrications.com/products/ranger/
Posted : 04/02/2015 11:38 am
BTR or Swarf will both do 12mm dropouts, as I guess would any custom builder like 18 Bikes, Shand etc.
'Steel Hardtail' is a bit generic though, what kind of frame is he after, XC, Trail, DH, wheel size?
Posted : 04/02/2015 11:41 am
Transition Trans AM
https://www.transitionbikes.com/2015/Bikes_TransAM.cfm
Farrer Cycles LoamRanger...
I think that's frame number 3
Posted : 04/02/2015 11:56 am
Pointless on a hartail IMO.
Posted : 04/02/2015 12:02 pm
Depends on the goal Shirley?
If you want to be able to swap wheels with your other bike for example I imagine it's exactly what you want.
+ many other possible reasons I can't think of
Posted : 04/02/2015 12:08 pm
Correct Amedias - wheel swapping between bikes.....
I have suggested adaptors to move to QR ๐Ÿ™‚
Cheers for all the replies....all look great, but expensive.....it is for a 'winter bike'......will look at 2H transitions though.....
Mark
Posted : 04/02/2015 12:33 pm
Funny that, I managed to pop my QR back wheel out on a steep corner at Inners the other week, on the BFe. A through axle probably would have stopped it. ๐Ÿ˜
Posted : 04/02/2015 12:43 pm
What makes it pointless on HT but not on FS?
Posted : 04/02/2015 12:47 pm
I should have qualified that. It's pointless for stiffness. Wheel retention, strength and compatibility I agree with. It's why my hartail runs 12mm ๐Ÿ™‚
Posted : 04/02/2015 12:59 pm
[i]Pointless on a hartail IMO.[/i]
hmmm, they're 'located' more firmly in the dropouts than QRs, might be a tiny difference fo'sure, but its noticeable all the same.
Posted : 04/02/2015 1:06 pm
Probably cheaper to buy a rear hub from Superstar that can switch between axle standards and have your LBS build the wheel up again.
Your mate would then only need to play around with hub adapters when he wants to change the wheelset between bikes.
Posted : 04/02/2015 1:15 pm
Loamranger now on my wish list just for the name!
Posted : 04/02/2015 1:20 pm
FS frames have swingarms moving around all over the place, so it helps stiffen the rear triangle up.
HT frames are inherently stiff being a pair of triangles. But a thru-axle can add to that stiffness.
Posted : 04/02/2015 1:23 pm
*most* 12mm <> QR conversion ends require removal of cassette as well, and at that point it's moving towards faff territory.
Posted : 04/02/2015 1:25 pm
sorry for the blatant plug but our production bike is available with 12mm bolt thru. The pic is singlespeed but available with derailleur hanger too.
[url= http://www.shandcycles.com/wp-content/themes/boot/images/bikes/bahookie-single/gallery/img1.jp g" target="_blank">http://www.shandcycles.com/wp-content/themes/boot/images/bikes/bahookie-single/gallery/img1.jp g"/> [/img] [/url]
Posted : 04/02/2015 1:31 pm
