Steel Hardtail - Ca...
[Closed] Steel Hardtail - Carbon/Ali/Ti Seatpost ?
Will be building up a Solaris and whilst the rest of the build spec is decided on (Reba/SID, hope xc wheels, x9 drivetrain, hope brakes). Not so sure on the seatpost, does a carbon/ti seatpost take some of the trail buzz or is it rubbish?
Posted : 26/07/2015 10:37 pm
Thomson.
(/Thread)
Posted : 26/07/2015 10:39 pm
It is a fat seatpost and less comfortable than my mtb with 27.2 but I went with the big T, just because
Posted : 26/07/2015 11:15 pm
In my recent experience of switching from a carbon post to a Thomson I noticed absolutely no difference. If there was less trail buzz when using the carbon I didn't feel it after it had already been dissipated by the tyre.
Posted : 27/07/2015 7:36 am
I had a 27.2 ti seatpost on my steel hardtail, and I used to think that bike had the nice steel zing to it.
Then I bought a steel road bike and put that seatpost on it, and thought that had the nice steel zing to it.
Then I broke the clamp bolt on the seatpost and put a deda carbon one on instead.
The 'steel' zing went and the bike was a lot less comfortable ๐Ÿ™
Ti post is now repaired and on my Tripster.
Posted : 27/07/2015 7:41 am
Yeesh, turnerguy which ti post was it?
how heavy are you?
Posted : 27/07/2015 8:04 am
Syntace P6 Hiflex - the only problem with it is it's not a dropper.
I have switched to a Reverb on the Solaris and it's way stiffer/harsher.
Make sure you use friction paste and tighten correctly (i.e. on the tight side), otherwise you'll get a very expensive scratch when it slips.
Posted : 27/07/2015 8:10 am
 adsh
^ +1 for the Syntace P6 shockpost
Moves about 2cm at the top if you have a decent length showing. Takes the edge of hits and is definitely a lot more comfortable. Even a USE sumo carbon moves a bit. The alloys stay rock solid.
Posted : 27/07/2015 8:43 am
Ti Sumo on my Soda - that's nice and sproingy.
If the bike in question has a fat seat tube, try shimming it and run a skinny post?
Wouldn't run a carbon post if you like dropping it on a regular basis - it'll get too scratched up.
All said and done, I'd probably give up the comfort of a flexy fixed post for the utility of a dropper myself...
Posted : 27/07/2015 9:28 am
how heavy are you?
old USE 27.2 post.
12 stone 6
Posted : 27/07/2015 10:27 am
Thomson posts have a bit of a reputation for slipping/creaking in Cotic steel frames....
Posted : 27/07/2015 10:33 am
Thanks for the replies, I have a Trance for trail/enduro work, the Solaris is for putting the xc miles in, so no need for a dropper.
The syntace looks a nice bit of kit, but will pass based on the cost. The USE posts do seem a good option, will have to see what length post I would need, the sumo carbon comes in a decent length (400mm).
Posted : 27/07/2015 12:09 pm
