Stan's ZTR Rim...
[Closed] Stan's ZTR Rims set up Tubeless - what do I need?
I've settled on Stan's Crest on Hope Pro 3 hubs for my new wheelset and would like to run standard Racing Ralphs tubeless, am I right in saying these are the things I need to do so:
[url= http://www.xcracer.com/shop/viewproduct.php?productid=116 ]Stan's rim tape[/url]
[url= http://www.xcracer.com/shop/viewproduct.php?productid=66 ]Stan's sealant[/url]
Is there anything else I need?
Posted : 11/08/2011 7:57 pm
Valves, unless the wheels come with them (they might).
Posted : 11/08/2011 7:58 pm
You'll need a valve
Ah okay, cheers, like this pair I take it:
http://www.xcracer.com/shop/viewproduct.php?productid=118
Setup isn't a problem as I'll have someone helping out, this tubeless stuff is black magic to me at the moment!
Posted : 11/08/2011 8:00 pm
Yeah they'll work. It's pretty simple, if you've got someone helping you, do one wheel whilst they do the other. You'll be an expert in no time.
I got the same rims - just use the yellow tape to seal the holes, trim the tape around the valve hole (with a stanley knife so you get a clean cut or with a file like on the stans website) and get 2 universal Stans valves:
http://www.notubes.com/Universal-35mm-Mountain-Valve-Stem-P558C16.aspx
Posted : 11/08/2011 8:01 pm
I'm assuming you've got a good track pump/access to a compressor/CO2 cartridge?
Posted : 11/08/2011 8:07 pm
I have a crap track pump but yes I do have CO2's ๐Ÿ˜‰
Posted : 11/08/2011 8:10 pm
double post
Posted : 11/08/2011 8:14 pm
If you need to use CO2 then once the tyre's sealed let it down and reinflate with the pump- CO2 will solidify the latex in the wheel in a day or two and you'll have no liquid sealant left in there to deal with punctures.
Posted : 11/08/2011 8:15 pm
Hope sell a kit with everything you need to turn the Stans rims into tubeless.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=49111&utm_source=google&utm_medium=shopping&utm_campaign=Google-Products-UK ]Hope tubeless Stans kit[/url]
Posted : 11/08/2011 8:17 pm
Cheers - so if I'm out on the trails and inflate with CO2 to fix a puncture I'd do well to let that out and inflate it with normal air upon getting home?
Posted : 11/08/2011 8:19 pm
I've always just set them up with a track pump, then if I've ever had to add air on the trail, just used a mini pump.
Posted : 11/08/2011 8:20 pm
Crests are a doddle with a track pump. Arches are a bit trickier.
Posted : 11/08/2011 8:27 pm
Try not to use C02 at all.
If you are out on the trail a repair usually involves an inner tube, so then the C02 doesn't matter.
If you use a tubeless repair kit to bung up a hole, then the tyre should still be seated. With any luck it will have only lost 10 - 20PSI by the time you plug a hole with the kit anyway.
Posted : 11/08/2011 8:48 pm
If they're the new, tubeless ready Schwalbes, then they'll go on with a track pump no bother.
Couldn't believe how easy mine went up.
Posted : 11/08/2011 8:59 pm
If you have trouble with them can definitely recommend this [url= http://www.singletrackworld.com/forum/topic/ghetto-tubeless-inflator-total-cost-9p ]Ghetto tubeless inflator[/url].
Posted : 11/08/2011 9:33 pm
You'll most likely need to keep topping them up with air for a few days at least. Took a couple of weeks for mine to settle down properly. Mine are Crests with non-tubeless-ready High Rollers. They were easy enough to get set up with a track pump, relatively speaking, but leaked air a lot at the start. Ace now though.
Posted : 11/08/2011 10:08 pm
Fairy liquid and a sponge!
Posted : 12/08/2011 12:05 am
