Stans Tubeless valv...
[Closed] Stans Tubeless valves in DT Swiss rims?
Hi guys,
Just received my YT Jeffsy and want to convert the wheels to tubeless.
They're DT Swiss M1900, does anybody know whether I can use Stans valves in these rims?
The DT valves look like they have a square bung, does this mate up with the rim?
Any help would be great!
Thanks,
Pete
Posted : 20/07/2016 8:59 pm
The DT swiss valves I bought had a curve on the bottom of the bung that mated perfectly with the curve on the xm401 rims I bought.
Posted : 20/07/2016 9:03 pm
didnt work for me had to buy dt swiss valves
only found out the other day that the other bit is for taking the core out. ๐Ÿ˜ณ
Sorry I got the valves confused ๐Ÿ˜ณ
Posted : 20/07/2016 9:07 pm
People buy proper valves? ๐Ÿ˜‰
All of my wheels are tubeless with valves cut out from old inner tubes.
One of the wheels is DT Swiss rimmed though, and it's been fine with said 'ghetto' valves, so should be fine with anything really!
Posted : 20/07/2016 10:09 pm
I couldn't get the DT Swiss valves to seal reliably in my DT Swiss EX471 rims ๐Ÿ™ They seem to be quite sensitive to how tightly the retaining ring is done up. Being ham-fisted, I probably overtightened them (then gave them an extra turn, just to be sure).
The Stan's ones worked (and are still working) fine.
Posted : 20/07/2016 11:06 pm
Stans valves are working perfectly on my DT XM481s.
Posted : 21/07/2016 6:41 am
Echo the above post, working ok in my XM481s.
Posted : 21/07/2016 7:46 am
Stans on EX471 working fine here.
Posted : 21/07/2016 8:07 am
I use superstar, of all the tubless valves I've used I've found these fit most rims
Posted : 21/07/2016 8:11 am
Did you check your box was empty. I got my Jeffsy about a month ago and the valves for covering the wheels (DT 1250's) where in the box.
Posted : 21/07/2016 8:12 pm
apparently they dont come with the M1900... bit odd but hey ho!
thanks guys, will use my old stans stuff and save money!
Posted : 21/07/2016 10:04 pm
Hey guys. See a few of you are rocking the XM481s. How are you finding them. I'm abut to pull the trigger on a pair. What hubs you running?
Posted : 21/07/2016 10:12 pm
Specialized valves in my DT rims, all good
Posted : 21/07/2016 10:18 pm
