Stan's No Tube...
[Closed] Stan's No Tubes vs Joe's No Flats - any difference?
Is there any difference between the two, or any reason to buy one over the other?
Thanks!
Posted : 23/09/2010 9:45 am
๐Ÿ˜ฅ
Posted : 23/09/2010 11:19 am
I have only used Stans and never had a problem.
Posted : 23/09/2010 12:33 pm
I have only used Joes and never had a problem.
Posted : 23/09/2010 12:35 pm
LOL - prob not then ๐Ÿ™‚
Stans strips seem better designed to me - they sit under the bead hook on the rim, they're a bit thicker etc. Joes strips look like bits of "pre-ghettoed" inner tube and sit in the rim overlapping the rim walls.
Used both, never had a problem with either but for some reason I feel more nervous about Joes burping. I can't quantify why - it's never happened with either but I'm a complete mincer so your mileage may vary.
Posted : 23/09/2010 12:41 pm
Stans is good.
Posted : 23/09/2010 12:42 pm
Joe's is gooderer.
And cheaper.
Posted : 23/09/2010 12:44 pm
 gamo
Used both with no problems,Joe's strips have always fitted in under rim
bead with me?
Posted : 23/09/2010 12:45 pm
Hmmm... that might be my lack of attention to fitting then. The strip seemed a little wide to sit under the bead when I installed it. Seems to work anyway, the bonus with Joe's is that the valve hole didn't need drilling.
Perhaps I should take it off and start again?
Posted : 23/09/2010 12:53 pm
Badger badger badger??
Posted : 23/09/2010 1:03 pm
Yoikes. Don't they both use Presta valves?
Posted : 23/09/2010 1:22 pm
Yes, but with stan's the strip is thicker at the valve so the hole in the inner skin of the rim channel needs to be drilled out to 10mm to make the strip sit flush.
It's not difficult but is a bit extra hassle making sure an sharp bits of swarf are removed. I was slightly concerned about taking a drill to my rim the first time but it's easy to do and allegedly doesn't affect the rim.
I think there's some videos on Stan's site...
...here you go - [url= http://www.notubes.com/support_movies.php?osCAdminID=cbb0524db009a16c4b807e8803642bf9 ]Instructional videos[/url]
Posted : 23/09/2010 2:58 pm
