Stainless steel bea...
[Closed] Stainless steel bearings, are they worth it ?
[#867301]
As title really, anyone use these and are they worth the extra cost?
When I have changed my bearings its corrosion that seems to be the problem.
With winter on the way will these last longer and maybe be able to regrease and use again.
Si
Posted : 14/09/2009 9:14 pm
Worth it compared to...?
Ceramic bearings are pointlessly expensive, and anything else (if there even is anything else) is rubbish and shouldn't be available from anywhere but Halfords.
Posted : 14/09/2009 9:23 pm
normal ones
Posted : 14/09/2009 10:26 pm
 sv
Yes worth it. simply bearings have a good selection & delivery.
Posted : 14/09/2009 10:34 pm
Stainless steel is softer than normal steel.
So they may not rust this time but they may wear out quicker. The best option if you ask me is ceramic hybrids - ceramic balls in Steel cages. You can even get ones which have a special coating which prevents the steel corroding. Bit expensive though.
Alternatively if you dont mind stumping up £80 per bearing full ceramics are an option.
since when ? Doesn't it blunt normal cutting tools ?
Posted : 14/09/2009 10:45 pm
Since it was invented i pressume.
Rockwell hardness:
Ceramic Ball (SI3N4) 75-85 Hardness
Stainless Race 58-60 Hardness
Steel Race 62-64 Hardness
2-6 point difference might not seem much but it means about a 20% difference in bearing life.
Posted : 14/09/2009 10:54 pm
http://www.singletrackworld.com/forum/topic/stainless-steel-cartridge-bearings-do-they-last-longer
stainless steel is ductile and work hardens considerably which is what knackers cutting tools.
normal steel? well of the thousands of different steels I guess you must mean EN1 mild steel, you'll soon know if some part of your bike is made from this...
Posted : 14/09/2009 10:56 pm
If corrosion is your problem and you don't want to pay for a ceramic bearing, then stainless is the way to go. Its good enough for chris king and plenty of others.
Alternatively, up your re-greasing regime. That depends on many factors of course, not in the least the ease of re-greasing.
Posted : 15/09/2009 9:32 am
Keep in mind that cheap ceramic bearings are not worth it IMO. You generally get what you pay for.
Posted : 15/09/2009 9:35 am
 jim
Bearing life due to wear? I think the bearings in an external bb (which I assume we're talking about here) will generally fail due to corrosion a long time before wear comes into play.
Posted : 15/09/2009 9:42 am
