Stages powermeter.....
[Closed] Stages powermeter....swapping from bike to bike
I have been looking at a Stages nds crank based power meter. My road bikes all run Shimano cranks with DA, Ultegra and SLX (on tourer). As they all have the same length cranks, can i just swap the Stages nds crank arm from one bike to the other depending what im riding?
Thanks
Posted : 23/09/2016 10:49 am
Yes, just swap it over. 3 or 4 minute job, I always use a torque wrench to 14Nm to tighten the pinch bolts.
Posted : 23/09/2016 10:52 am
Yep, I regularly swap my MTB Stages from bike to bike. Super easy, although all are running XT cranks (so they match rather than compatibility reasons).
Posted : 23/09/2016 11:25 am
Yeah, should be easy. Check if the road and MTB cranks are interchangeable though, I fear they may not be.
Posted : 23/09/2016 11:33 am
Ok, so the swap of DA/Ultegra seems easy...it appears i will have to see if a road nds crank will fit on an slx chainset....
Posted : 23/09/2016 11:36 am
It won't IIRC, the q-factor is very very different.
Edit: well it will, but it may hit your chainstays and the whole thing will be lopsided.
Posted : 23/09/2016 11:40 am
Tip : use the same pedals on all bikes so pedal removal isn't needed. Otherwise it might take a bit longer ๐Ÿ˜‰
Posted : 23/09/2016 1:25 pm
yep I swap mine between turb0 bike and road bike - 2 min job!
Posted : 23/09/2016 3:30 pm
As per other replies, yes if its between road bikes, no (or unlikely) if its to fit a road non-drive side to a mtb drive side - the non drive side will most likely clash with the chainstay.
Posted : 23/09/2016 6:28 pm
