Stack Hieght of int...
[Closed] Stack Hieght of intergrated Headset
What is the stack height of a intergrated headset?
Jon
Posted : 01/02/2010 6:49 pm
Depends on the headset! ๐Ÿ˜‰
On my FSA it's about 2mm at the bottom, and maybe 6/7mm at the top.
Posted : 01/02/2010 6:54 pm
Also depends on how low you want to go...you dont always need to use the top caps on the upper cup if you want it lower.
Why?
Posted : 01/02/2010 6:58 pm
Because I am getting a new frame with intergrated head set, and HT length of 124mmm and want to know if forks with steerer 170mm will fit, my stem is 40mm
Posted : 01/02/2010 7:07 pm
