S/s sprocket on Pro...
[Closed] S/s sprocket on Pro II alloy freehub?
Apologies if this has been up before, but I want to run a different set of wheels on my singlespeed. I've got a Surly sprocket, and while it's a wider footprint, am I risking chewing up the alloy Pro II freehub so much that I won't be able to go back to a 9 speed cassette?
Any views?
Posted : 16/02/2009 7:11 pm
Should be ok with the surly ones. You can always file off the burrs anyway, it's what I had to do when I changed casettes on mine.
Posted : 16/02/2009 7:14 pm
[img] ?v=0[/img]
You'd be much better off with a steel freehub body.
Posted : 16/02/2009 7:15 pm
Ive not heard of any problems with any of the wider sprockets on alloy freehubs whether you're using Surly, Boone or On-One Groove Armada (Ive just started using the latter on an alloy freehub)
EDIT: Well, there you go, first time Ive seen a wide footed notch in an alloy freehub? Are you built like Victoria Pendleton or something barnes? ๐Ÿ™‚
He has a set moobs? ๐Ÿ˜†
Posted : 16/02/2009 7:26 pm
and a very odd chainline!
Posted : 16/02/2009 7:28 pm
Not my hub, it's a friends. She's quite a strong rider though ๐Ÿ™‚
Posted : 16/02/2009 7:30 pm
Simon, what does she look like from behind?
Must have legs like Hoy to do that...
Posted : 16/02/2009 7:51 pm
You should be fine to use a Surly cog on a ProII, [i]provided[/i] you get the lockring up to the correct torque ie 40Nm. Its the same with using a full cassette, if you only do it up handtight, as soon as you put any force through the system, the splines will take all of the stress, leading to a chewed freehub body.
Posted : 17/02/2009 11:30 am
 Olly
ide say get a steel freehub body if you have the wheels already.
if not, ure in the same situation i was in a few months back, wanting a wheel good stonrg and reliabe for SSing, but capable of taking 9sp, and went with a second hand Hope XC instead (40 quid for a wheel, the rim i wanted on the hub i wanted)
Posted : 17/02/2009 12:35 pm
[i]if you only do it up handtight, as soon as you put any force through the system, the splines will take all of the stress[/i]
and just how do you think the power is transferred to drive with the lockring done up to 40Nm? Magnetism?
Posted : 17/02/2009 12:37 pm
 ski
That's quite impressive Simon, any idea how long that took to do?
Posted : 17/02/2009 12:41 pm
Olly - thanks for the steel suggestion, I realise that's the best answer. The current wheel has a steel XC freehub, but I wanted to swap my Pro II alloy set onto the bike as it means I could run it tubeless (I'm sick to death of undoing all the chaintug gubbins following an endless stream of punctures). In my case, I don't want the cost of a new freehub, so I thought I'd see if I could "get away" with the alloy freehub for a while.
Appreciate the suggestion from GavinB about doing it up really tight, but the picture from Simondbarnes is rather striking - it may have just convinced me to put up with endless punctures!
Cheers all.
Posted : 17/02/2009 1:04 pm
 Olly
or go for a gehtto tubeless?
or for the price of a new rim go proper tubeless?
i pressume its pinches your suffering from.
you could puncture proof your tyres trials style?
a length of seatbelt, sat between the tube and the tyre, prevents pinches (i think because its hard to fold) without costing a fortune in trials specific tyres.
run it on my street/dirt bike for aaaaaaages
Posted : 17/02/2009 1:18 pm
Thanks Olly. Actually, it's thorns mostly round my way, but to put the little devils in context, in the last 2 short rides I have had 5 punctures!
I'm totally confused "how to" tubeless - does ghetto mean using a Stan's type kit on non-UST tyres? I gave up about 2 hours in to reading a mass of conflicting websites....!
Posted : 17/02/2009 1:32 pm
 Olly
tubeless is mainly for pinches iirc.
slime tubes work brilliantly against thorns, but they are a bit heavy, and make a massive mess if they do pinch.
slime also do a protective strip that is supposed to be pin proof, that goes between the tyre and the tube.
when i was riding country lanes in shropshire as a kid, i always used slime tubes.
stopped using them because i moved to wales and u dont get thorns out there, just pinches.
ghetto is homebrew i think.
as a rim liner, you can use a BMX tube, and then any sealent of your choice, on any old tyres.
ide erccomend you give slime a try, for about 7 quid a tube, not a massivly expensive experiment.
they are a bit heavy, but think of it as training ๐Ÿ˜‰
Posted : 17/02/2009 1:45 pm
Thanks again. I'll give 'em a go!
Posted : 17/02/2009 3:11 pm
Tubeless is great for thorn type punctures not just pinch flats/snakebites, just look at the Stan's video riding over the nail board :p You can't just use any old tyre though (even with ghetto tubeless) as some have too weak beads or too porous sidewalls and will burp or just not seal.
Posted : 17/02/2009 3:20 pm
