SS newbie issue
[Closed] SS newbie issue
 jfeb
I have recently bought a Singular Gryphon build up as a singlespeed. I swapped the 16 tooth rear cog for an 18 tooth one and changed the chainset. I had to adjust the EBB as a result. Since doing this there is a grinding feeling like tight/mis-aligned bearings when pedalling with any pressure. It feels like it is coming from the BB but I can't be sure.
I have tried refitting the chainset in case I somehow did something wrong there but the grinding persists. I can't refit the old rear cog because I can't get the cassette lockring off with my DIY chain whip so a proper one is in the post but I can't see how it really can be that either.
Any thoughts?
Posted : 11/06/2010 6:46 pm
maybe the chain is too tight?
Posted : 11/06/2010 6:48 pm
old chain/new cog?
new chain/old cog?
Posted : 11/06/2010 6:53 pm
Sounds like it's too tight to me. Chainrings aren't, perfectly round, is it at the same point in the chainring revolution?
APF
Posted : 11/06/2010 7:09 pm
Does the chainset feel tight with the wheel and chain removed ?
Does the sproket and freehub feel tight out of the frame ?
If the answer is no then sounds like a chain issue
hope this helps
Posted : 12/06/2010 1:21 am
 jfeb
Thanks chaps.
The grinding happens with a slack chain as well as a tight one (I initially thought it was a tight chain causing the issue).
Chainset isn't tight without wheel and chain, neither is the sprocket/freewheel. And the chain was fine before I changed the chainset and sprocket.
I am waiting for a proper chain whip to be delivered (my chain + claw hammer usual bodge isn't working) and I will put a) the old 16tooth sprocket on and b) the old chainring on the chainset and see if the grinding disappears. Thanks for your thoughts though.
Posted : 14/06/2010 4:11 pm
 Del
as sss,
old chain + new cogs. it'll quieten down after a ride or two. or change the chain out.
Posted : 14/06/2010 8:01 pm
3/32 chain on 1/4 cogs?
Posted : 14/06/2010 8:03 pm
