SRAM XX1
[Closed] SRAM XX1
I'm with Messiah here. We ride similar stuff and I also have a Hammerschizzle for similar reasons. I'm running 1x10 on my big bike and sometimes. like the weekend, its just not low enough, like at the weekend in Wales with steep hills and thick mud after 9hrs riding. Now, I dont mind the walk, a compromise I'm willing to make, but I'd like a lower option (tho it could look minging)
This could well be my one solution and eliminate my need for a hammerschmidt.
The bugger is only DT rear hub compatibility. I run CK and maybe they'll make a freehub to fit we'll see. I could of course swop out the hub for a 240s, but I think I'll wait and see if CK does one of these babies.
Posted : 03/07/2012 10:17 am
All in I think this looks like a great groupset.
The suggested price is an utter joke of course, but then again they always are on new stuff. I'm sure next year we will see a cheaper version.
I really hope shimano do something similar soon...
Posted : 03/07/2012 10:24 am
Shouldn't it be X1?
They're X short of gears. like the whole 1x thing but that 42 looks like a big jump - kind of Apex for enduro, cant be ar*ed counting the teeth on the next one in but it doesnt look like an even spread to me - first person to do it wins a prize.
Posted : 03/07/2012 10:32 am
I've loved the idea of this since I first saw it.
I've often considered going 1x9, but the need for a weird small chainring (the Widgit) to keep my low gears has put me off.
I would probably partner the 10-42 with a 30t chainring (available 28, 30, 32, 34, 36, 38-teeth). I've never been one to use the really high gears anyway.
The whole ground-up development of this is the biggest innovation in gearing for donkey's years.
I don't like SRAM as a rule, but this has got me thinking.
Posted : 03/07/2012 10:38 am
I wonder if they will add a Quark power meter to the chainset - the 'ultimate' singlespeed option!
Posted : 03/07/2012 10:48 am
I currently run 1x10 with a 30t ring and 12-36 cassette, I can climb pretty much anything with this and after a year or so it feels ridiculous jumping on something with a granny (road runner legs). This system looks cool but the price is laughable, wouldn't the chain line be stupid too?
Posted : 03/07/2012 11:05 am
If they do it won't be until 2025! I'd get some DTs!
Quarq*, but why would that be the ultimate SS option? You have loads of chainset mounted power meters that will work with SS, can't see this brings anything new to the party for SS.
Posted : 03/07/2012 11:06 am
Ratherbeintobago and Messiah - thank you for both those answers. I now understand a lot more. 🙂
I believe the chain line is no different to a 1x10 or 1x9 setup since the freehub body is the same width.
Posted : 03/07/2012 11:17 am
They'll be a fixed (ish) percentage between them. It goes 32-36-42, which makes the last jump 16% (normal gears are 13% give or take a bit, 32->36 is 12.5% for example). So it'll be slightly spinnier than you're expecting, but only 3% (1/3rd of a gear) spinnier. And it looks to be intended as a bail out gear for non-compettattive sctions on Enduro's, leaving a more normal 36t bottom gear for raceing (and giving a few extra top gears for the fast boys at the other end).
Posted : 03/07/2012 11:22 am
Shouldn't it be X1?
That's my main issue with it, pedant that I am, XX1 is 21!!! Other than that I'm not too bothered, internal cable routing has solve many front mech issues for me, I do like single ring set ups, but I'll wait before jumping up to this, see if it sticks around, or we're all running XX2 XX11 or whatever in three years time...
Posted : 03/07/2012 11:28 am
Doesn't the big cog sit over the spokes, so making the chainline approx 1 cog wider.
I'm sure their chain design and tooth profiles allow for this. They seem to have all bases covered.
Posted : 03/07/2012 11:31 am
Yeah but following SRAM's naming tradition X1 would be a bottom of the range group! Think of this as single ring XX and XX1 makes more sense, ignore the roman numerals thing!
Or... consider that XX was more X.10 (as opposed to X.5/X.7/X.9 etc) rather than 'twenty', and XX1 makes sense.
Over thinking things? Me? Nah!
Posted : 03/07/2012 11:32 am
packer - Member
Tricky thing with a cheaper version is the cassette - without the all-singing, all-dancing machining that's used for the top of the line one, a 10-42 cassette will be a ton weight.
Posted : 03/07/2012 11:36 am
I'm guessing here... but due to this groupset being pretty much focused on those entering super-enduro's etc SRAM may choose not to release (or even work on) a cheaper version?
Which would be shame as I think it would be good for all sorts of biking... but who knows 😐
Posted : 03/07/2012 11:44 am
Wasn't the Hope freehub/cassette gonna be 9-36t? It makes more sense to me to make things smaller and lighter, ie sprockets and chainring to achieve the same ratio and better ground clearances. Like the way that mech shifts in the video though. Plenty of RandD going on so the first ride review will be interesting....
Posted : 03/07/2012 11:50 am
In the official video, SRAM talk about starting with a 9t, but eventually settling on a 10t.
Posted : 03/07/2012 12:00 pm
I worked it out; my current drive 2x8 36/22 with 11-30 cassette goes from 19.1 to 85.1 gear inches overall.
XX1 using a 32t ring and the 10-42 cassette would give me 19.8 to 83.2 gear inches so almost replicates the gear range I currently use without the ratio duplication or extra components/faff that come with having 2xN...
An 11-43 with a 34t ring would produce 21 - 80.3 Gear inches which wouldn't be a bad overall range but actually 10-42 seems to offer that little bit more...
Whatever happened to the Hope 9-36t cassette? will it/has it ever come on to the market?
Posted : 03/07/2012 12:58 pm
im interested in trying the chain ring in a 1x10 setup - with a shaddow + rear mech.....
Posted : 03/07/2012 1:25 pm
More XX1 information dribbling out.
[url= http://www.bikerumor.com/2012/07/07/hands-on-sram-xx1-1x11-group-details-pics-more/ ]drool[/url]
Posted : 11/07/2012 10:35 am
And Spesh fitting it to S-Works Epics for 2013, so they see a market for XC racers.
Posted : 11/07/2012 10:43 am
For my bike (29er), I'm on 2x10 with 22/34 and 11-36 - that's about 500% range
XX1 has 420% range so not a massive change, particularly as I could definitely live without 22/36
Posted : 11/07/2012 11:17 am
ratherbeintobago - Member
It looks like it's designed in such a way that the upper jockey wheel isn't coaxial with the pivot as on normal mechs; the upper jockey wheel tracks the cassette by rotating the whole cage:
Just like shimano then!
Posted : 11/07/2012 11:18 am
Indeed but much more so which means the parallelogram doesn't need to be slanted (like current mechs) to follow the cassette which in turn, theoretically at least, means it should be less affected by vertical forces
Posted : 11/07/2012 11:23 am
Patiently waiting for the Hope 9-36 cassette here too.
I switched to 11-36 with a hammerschmidt and while it´s great going up
I´m missing an extra push for flat/downhill bits.
As soon as I see Sram & XX I don´t bother reading more, silly prices, it even makes xtr look inexpensive.
Posted : 11/07/2012 11:35 am
With a modicum of fitness 34/36 gets you up most things at a faster than walking pace.
Posted : 11/07/2012 12:13 pm
With a modicum of fitness 34/34 gets you up most things at a faster than walking pace .
There I am harder than you .
Posted : 11/07/2012 12:32 pm
clubber - Member
what vertical forces? The same ones dealt with by lateral stiffness and vertical compliance? 😀
Posted : 11/07/2012 12:36 pm
It does look really good. Only two downsides for me:-
[b]1) [/b]Cost
[b]2)[/b] "[i]…SRAM dished the 42T cog (which serves as the backplate) to follow the contour of the spoke angle a bit and take advantage of otherwise wasted space. Brilliant.[/i]"
....As something of a specialist at stuffing the rear mech into the spokes I am a bit worried about perilously dangling a £150 rear mech even closer to them - I think I'm gonna need a dinner plate sized dork disc as protection...
Posted : 11/07/2012 1:29 pm
Nah, you hit a bump, the wheel moves up as does the rear mech mounting point. On a slant mech, there's a vertical force applied to the cage which can move it, causing ghost shifting. In theory... In the real world, I'd like to try the XX1 to see whether it really makes a difference.
Posted : 11/07/2012 1:43 pm
Whyte 146 will be available with XX1
Specialized S-Works Enduro, Epic and Stumpy hardtail will be available with XX1
I think we will see a lot of bikes appearing (in brochures and on the interweb) with XX1 over the next few months... the more I see it the more I like it.
Posted : 11/07/2012 2:47 pm
Already posted this in the "[i]show me your 1x10[/i]" thread but might be of interest here - XX1 on Schurter's bike:
[img] https://instagr.am/p/M-Ok_zsxt8/media/?size=l [/img]
Posted : 12/07/2012 8:36 am
That is interesting, well done!
You'll be lucky, XX jockey wheels are £120, you'll not get change out of £300 for a mech at retail!
Posted : 12/07/2012 8:41 am
Interesting that Specialized have put on a chain device. Maybe it's only on the Enduro, but it would be interesting to know if they've tested and decided it's needed, or whether they just took a guess.
oh - and that dinner plate 42t cog looks massive!
Posted : 12/07/2012 10:46 am
Page 2 / 2
