SRAM XX1
[Closed] SRAM XX1
[#4264683]
Who's tempted? The cost is going to be massive but I really like the look of it. I wonder what the weight loss would be over my XT/XTR 2x10 set up? The freehub compatibility thing could be an issue mind, although Hope must be thinking about some sort of adaptation.
Thing is, as an upgrade (in terms of cost) its going to be pretty huge. I'd NEED to be sure....
Posted : 16/08/2012 11:45 am
I think the chain retention offered by reshaping the teeth is a brilliant idea.
Posted : 16/08/2012 11:51 am
If I had the money definetly. Xx1 on a carbon covert is my current ultimate bike
Posted : 16/08/2012 11:54 am
 v10
Works out at about 1k for the group.
Mines already on order 😆
Drivetrain:
Chain PC XX1 HollowPin 118 links PowerLock 11 speed £49.99
Shifter XX1 Grip Shift 11 speed Rear w Locking Grips £129.99
Shifter XX1 Trigger 11 speed Rear w Discrete Clamp £139.99
Rear Derailleur XX1 11 speed £239.99
Cassette XG-1199 XX1 X-Glide 10-42 11 speed £329.99
Chainsets:
SRAM Crank XX1 Q-factor 156 170 32T GXP Cups NOT included £249.99
SRAM Crank XX1 Q-factor 156 175 32T GXP Cups NOT included £249.99
SRAM Crank XX1 Q-factor 168 170 32T GXP Cups NOT included £249.99
SRAM Crank XX1 Q-factor 168 175 32T GXP Cups NOT included £249.99
SRAM Crank XX1 Q-factor 156 170 32T BB30 Bearings NOT included £289.99
SRAM Crank XX1 Q-factor 156 175 32T BB30 Bearings NOT included £289.99
SRAM Crank XX1 Q-factor 168 170 32T BB30 Bearings NOT included £289.99
SRAM Crank XX1 Q-factor 168 175 32T BB30 Bearings NOT included £289.99
Chainrings:
XX1 Chain Ring 28T 76BCD Alum 6mm Artic Grey 11 speed £69.99
XX1 Chain Ring 30T 76BCD Alum 6mm Artic Grey 11 speed £79.99
XX1 Chain Ring 32T 76BCD Alum 6mm Artic Grey 11 speed £79.99
XX1 Chain Ring 34T 76BCD Alum 6mm Artic Grey 11 speed £89.99
XX1 Chain Ring 36T 76BCD Alum 6mm Artic Grey 11 speed £89.99
XX1 Chain Ring 38T 76BCD Alum 6mm Artic Grey 11 speed £99.99
Posted : 16/08/2012 11:56 am
V10 who did you place the order with?
Posted : 16/08/2012 12:03 pm
Himself probably!
Posted : 16/08/2012 12:07 pm
 v10
whoever he's working for this week, I imagine 🙂
Hubs is the problem. Well, not a problem. But it's got to be DT Swiss or Mavic for now I think.
Posted : 16/08/2012 12:08 pm
The only thing that bugs me is the cost of the replacement cassette. Everything else I can deal with, but a component that I seem to wear out in around 2000km (10spd xt) costing £350 is a bit hard to stomach.
Posted : 16/08/2012 12:14 pm
FARK me, I knew it would be a lot, but.........
I'd be tempted if
a) it was made by shimano and therefore made from cheese, but at least it would Edam rather than primula so the mechs might survive one lap of stainburn.
b) the cassette was 11-42 (and therefore fit on a normal hub),
c) the chainring was a normal BCD, but then I bash my ring a lot so I'll ptobably stick with a full chain device.
I wonder if Shimano will respond? They didn't really to XX, they just made XTR (and everything else) 10speed (but then so did SRAM with X.0/9/7). But this seems sufficiently different, and they've got a new road freehub standard with the lastest 11 speed DA.
On the other hand assuming SRAM have patented the overhanging cassette idea, then I can't see it taking off, we've not had a new freehub since 7 speed, and even then they were backwards compatible for a while with threads inside and out. Would people throw away their old hubs for a new standard?
Posted : 16/08/2012 12:15 pm
hopefully the lathes in Barnoldswick are currently spinning with a feehub we can retrofit to pro2 hubs.
and hopefully SRAM already have drawings of X9 11 speed made up
and even then I will struggle to afford it
 v10
I left before you did Brant!
Posted : 16/08/2012 12:16 pm
My record is about 500m for a SRAM X.9 mech, that's 14p per meter!
Posted : 16/08/2012 12:17 pm
I've spoken to i9 and they've got permission\drawings from Sram to produce a freehub (but no eta).
Posted : 16/08/2012 12:20 pm
DT (or Roval/Bontrager) or SRAM for now.
30 yards for a brand new Rocket Ron: £1.65 per mile.
Price seems pretty 'reasonable', XX money at least. I'm still not convinced by the cassette, I think the jump from the 10 to the 12 will mean it's only really useful on very fast downhills, rather than as a sequential gear, if you know what I mean. Reckon it'll wear fast too. Would rather have seen an 11-42 or something for normal freehubs, but where's the money in that for SRAM!?
If building a new bike I'd almost certainly do it, can't see I'll change though.
Posted : 16/08/2012 12:23 pm
 v10
The freehub body is no wider than a current one. Most peoples current hub shells/wheels will be compatible when/if the wheel/hub manufacturers machine some freehubs.
Posted : 16/08/2012 12:24 pm
Oh duh, of course, I remember who you work for now 🙂
Hah
Stupid thing is I can't buy SRAM XX1 compatible OE hubs until Feb 2013!
Posted : 16/08/2012 12:28 pm
There's none anyway, well unless people suddenly start buying SRAM hubs which aren't very common at the moment, but that wont change if everyone eles makes compatible hubs anyway.
Posted : 16/08/2012 12:29 pm
This^^^ As part of a new build the upcharge would not be huge, but to swap out a drivetrain for £1000 is ouch 🙄
Plus... my experience with SRAM (other than my HammerSchmidt) so far has not been too positive (My X9 was sheeeeeeeeit).
I emailed HOPE in July and they replied to say they had no plans to produce a compatible hub body... but I'm sure that will change if/when they see demand.
Hi, we have no plans to make a compatible freehub at the moment. We would have to have a look at the cassette etc first as we have no experience of them yet. Very sorry about that.
Cheers,
Dart.
Rather than buy XX1 I would prefer to get the HOPE 10 speed 9/10-36 cassette that was rumoured; then I could use Shimano Saint/XTR stuff... but I would be very tempted by the XX1 crank to get those chainrings... but how long until other companies copy that idea???
Posted : 16/08/2012 12:52 pm
Well about the same price as my Rohloff but the in 6 years I've only bought one chain one rear sprocket and the oil.
I really like the look of it but as I'm coping fine with 1x9 I think I'll just be going 1x10 when that needs replacing.
Posted : 16/08/2012 1:01 pm
So what does XX1 do that a Rohloff doesn't? Except it's fewer gears, exposed mech, more expensive, chains and cassettes will wear more quickly because of the extreme chain line, oh and that 42t rear sprocket looks ridiculous!
Posted : 16/08/2012 1:13 pm
It doesn't drag like a Rohloff.
It doesn't weigh as much as a Rohloff, particularly right at the back of the bike.
It doesn't look crap like a Rohloff (well, you started it with the 42t sprocket comment 😀 )
For many, those are big reasons not to have a Rohloff. YMMV
Posted : 16/08/2012 1:20 pm
Weighs a shitload less.
I've tried and owned various Rohloff bikes... your either willing to put up the negatives or your not. Going back to a normal drivetrain felt great to me which shows me where my allegiances lie (wa-ay to go to off-topic the thread by the way 🙄 back under your bridge 😉 ).
Cassette wear is not a huge issue as long as your meticulous with the chain wear checker and change the chain ealier rather than later. But smashing a £240 rear mech is always going to hurt... my record was two in two days and it was one of the reasons I went Rholoff all those years ago 😆 (and also the reason I now run SXL/XT/Saint rather than XTR... £240 for something dangling down there is a bit scary 😐 ).
Posted : 16/08/2012 1:21 pm
What he said +1, my only experience of Rolhoffs off road is waiting for people with them to fix their 3rd pinch flat of the decent.
For £1k+ though (so realisticaly £2k+ after 2 years hard use inc a couple of mechs, cassetes and loads of chains)? How much do you reckon you'd need to pay Orange to do a protorype 5 with a pinion 'box? They must surely have considdered it as if ever there was a designed that leant itself to bolting bits on under the BB it's their folded sheet monocoque.
Posted : 16/08/2012 1:23 pm
Yep... been there too 😆
Posted : 16/08/2012 1:25 pm
And on this, the chainline is no worse than 1x9 or 1x10 that lots of people are using without issue. In fact, because the biggest sprockets are bigger than a standard cassette, in theory the wear should be reduced (though admittedly you're comparing alu and steel).
If I had the money [s]definetly. Xx1 on a carbon covert is my current ultimate bike[/s] I'd spend it on nice beer, wine and food and maybe a week in the alps instead
Posted : 16/08/2012 1:29 pm
I don't think I've ever replaced a 44t outer chainring due to wear, usualy they just get eaten by rocks or replaced because the middle and inner were worn and a set of 3 was cheeper.
I used to wear them out. These days not 🙁
Posted : 16/08/2012 1:33 pm
I find that chain wear is significantly reduced on 1x10 anyway, can't see this will be any worse as the extremes are the same.
Posted : 16/08/2012 1:54 pm
Jesus - sorry I ever used the R word. I wasn't comparing them just referring to the fact that if I spend a grand I want something that lasts a long time.
My Rohloff is on a rigid bike ridden off road everyday to work all year round which is never cleaned and it's been faultless for 6 years. There is no better option if you don't want to go single speed. I also have a hardtail with a 1 x 9 set up because that is much better for when I want to go quickly. There is no point comparing them unless your the sort of person who puts screws in with a hammer. 🙂
Posted : 16/08/2012 2:08 pm
I do want XX1, but don't need it...
How about an X9 level 10 speed, 11-42 ish, normal chainring, normal shifter and chain device...
Then I could get the range of gears I need without spending silly money...
Posted : 16/08/2012 2:47 pm
just for you avdave 🙂
http://answers.yahoo.com/question/index?qid=20101201092200AAXpc9E
Posted : 16/08/2012 3:25 pm
Do you have to buy a new crankset? Will the new fancy-dan chainrings not go on a bog standard crank arm?
Actually, do you NEED the new chainrings? Wont a good singlespeed chainring be nearly as good?
Posted : 16/08/2012 3:41 pm
At holding the chain on, no, but if you use a chain device then it's not really nececary. And they're a unique size (which is an annoyingly pointless way of forceing you into crapy GXP chainsets.
Posted : 16/08/2012 3:43 pm
76mm BCD (or something) new cranks definitely required.
Not really, no chain guide required with the pukka XX1 ring.
Posted : 16/08/2012 3:48 pm
Sods, they could have saved some people some cash by making the chainrings with a standard BCD.
Posted : 16/08/2012 3:52 pm
I'm sure it'll be only a matter of time before someone comes up with a XX1 style chainring that'll fit normal 4 bolt chainsets - middleburn/hope maybe?
erm Wouldn't it be nearer £1800 a mile?
Posted : 16/08/2012 3:56 pm
I am not terrible up to speed with all chainring BCD permutations, but this one lets you run a 28t "middle" ring as it were.
Posted : 16/08/2012 4:00 pm
Just thinking the same. With my shoes and socks off I make it nearer £3!
Was your tyre £49.50 N?
Posted : 16/08/2012 4:01 pm
Ah yes, meant per metre! Quick mental tot up based on £50 tyre.
Why would they do that though!? It's actually pretty neat - can easily be changed without removing the cranks, neat way the bolts thread in, and the profile of the spider means you take the pressure off the bolts as you pedal - less shear force.
Posted : 16/08/2012 4:08 pm
I can't work out if it's just clever tooth profiling for better shifts, or whether the cassette in bikeradar's review photos is already really worn. If it's the latter, that's a pretty quick way to spend £330...
Posted : 16/08/2012 4:13 pm
interesting http://www.pinkbike.com/news/sram-xx1-ride-11-speed-2013.html
Posted : 17/08/2012 8:44 am
