Hi all all the main body parts have small type cir-clips and pins through so im guessing yes,the part that holds the gear cable plastic bit what says 10 speed bit..looks like its rivited on but small pin through & cir clip tried taking off but didn't budge with hole punch and hammer..
Help before i get big hammer out ๐ฅ
Can all the linkages be [s]took apart.[/s] taken apart?
๐
Thats what i meant well.....? ๐ฏ
I have tried taking one apart ,easy enough to get the circlips off and I could drive out the metal pin but there appears to be a plastic sleeve/bushing that would not move which seemed to retain the body parts still.
I assume it is removable but do not know what with or,whether its a sacrificial part that needs to be replaced after destructive removal ie.Drilling out.
unovolo - Member
DITO bud as i tried and i nearly smashed the monkey metal pin flat LOL
Noticed the silly grey inner sleeve too looks like it DOES come apart but why doesn't it,as i need to replace the broke cable guide..
Very annoying as looks a simple job on paper but...... ๐
Wonder if Sram any takes on this..? ๐
I hate been beaten ๐ณ
