Well it jams intermitently, the small allen key hole to remove it has rounded, so cant get it apart, so how can i seperate the wheel from the cage,if i drill it out i need a new wheel and bolt, and does anyone please have a spare wheel and bolt.
Strangely it turns freely both ways and then suddenly jams a bit of pushing and turning frees it up, to rotate again.
Ps is it a warranty issue, bikes abiout 3 years old and a spesh 😯 😳
It will be the bearing inside the jockey wheel. mine goes after 6 months so you have done well! New bearing costs less than a quid on ebay. Need to take off the other bolt then try to turn the whole cage and free the bolt or drill it out. Having said that 3 years for a rear mech is good going so due for a new one!
C
well just drilled it out, the bolt appeared to made of cheese so soft, all the little balls ran for safety ,so looked for a replacement wheel,(jockey wheel that is)£19 .00 quid from CRC, bloody rip off,not CRC but Sram.
Not a happy bunny now.
I've got some brand new still in original packet for sale £10 posted.
Go for BBB replacement jockey wheels. The top X9 runs on a bushing but the BBB set replaces both with sealed cartridge bearings.
I replaced my x9 jockey wheels with i x7 and they worked fine.
I suspect that these would fit too http://www.chainreactioncycles.com/Models.aspx?ModelID=49731
As for getting the plate off, take out the other bolt and wind the cage off. Reverse the process to put it back on.
i have a spare if it is not too late cage and goodish bearings and jockey wheels any use?
http://www.cyclesportsuk.co.uk/product_info.php?products_id=7418
bit cheaper than SRAM, though still incredibly expensive....
When you put the new bearing in , fill the void with thick white grease . The gap between the silver plate and the bearing cover is large enough to hold the crud, the white gease wont stop the crud getting in there , but holds it outside of the bearings, then once a year wipe out the white ( now black ) grease and refill. Simples.
3 years and £19 for replacements? That's a bargain, plenty of people kill mechs in less time.
I destroyed some XX ones in 3 hours, they're £120.
BBB Rollerboys are spot on and not expensive. Longer lasting than the SRAM originals.
I use Tacx ones, find they last well, but I don't think they're any cheaper than the SRAM ones!
