sram x7 s1400 24-38...
[Closed] sram x7 s1400 24-38 off T129s Question ?
As above I would like to try a 22 tooth chain ring. Do I need to change both and run 22-36? and where can I buy them at a cheap price?
Posted : 16/07/2013 11:51 am
22? Where are you riding?
Posted : 16/07/2013 12:39 pm
I hired a couple of bikes at weekend that seem to climb better than mine, so was just wondering about trying lower gearing to see how it went. I've also noticed on some spec' sheet that the 2014 version of my bike comes with 22-36 but I may be wrong, I was just keen to maybe give it a go. On the other hand I may need to just get fitter ๐Ÿ™‚
Posted : 16/07/2013 12:51 pm
[i]On the other hand I may need to just get fitter[/i]
this ๐Ÿ™‚
I can't believe that 'climbing better' was caused by having lower gearing available, imo if you're in the granny ring and up the top of the cassette then it's time to either get stronger or walk as it'll be quicker.
Posted : 16/07/2013 12:55 pm
well that's me told, cheers you've saved me wasting a few quid, the hill in question is the pennine bridleway going up from Cowpe there is a bend that I just can't get up. I think its the geometry of the bike as I end up pulling wheelies TBH..
Posted : 16/07/2013 1:01 pm
 mboy
Having ridden a T129s, I can say its a good climber for a mid travel FS bike. If you're pulling wheelies lean forward more, possibly lower your bars a bit, and check the rear shock pressure isn't too soft for your weight.
Posted : 16/07/2013 1:04 pm
Thanks Mboy I will look at those things..
Posted : 16/07/2013 1:07 pm
I've got the same bike, being honest I think going to a 22 would be a waste of money and time. When I first got it I did find it more difficult than my old 26er with a 32/22 but now I'm climbing most stuff in the 38! I'm going to go 1x10 with a 32 on the front at some point. It'll hurt at first but i should get used to that too. I live and ride in the lakes mainly so lots of tough climbs here.
Posted : 16/07/2013 1:14 pm
I'm the same with the front end lifting, I do struggle a bit with that aspect, even if I get my weight right forward. I'll be getting wider bars and moving spacers above the stem if I keep struggling. I just love how it descends as it is though!
Posted : 16/07/2013 1:17 pm
32 11x36 in the Alps for me, with a fair bit of climbing. I can do it and I'm not racing whippet.
if you have problems with front end lift get your elbows lower than your hands/grips and slide forward on your saddle.
Posted : 16/07/2013 1:26 pm
