SRAM X01 Eagle spin...
[Closed] SRAM X01 Eagle spindle
Hey guys,
I have a 2018 Stage 5 Factory which is running X01 Eagle carbon cranks, I am wanting to replace the BB and order one online as my LBS doesn't have any in stock to fit so I am supply it.
However can someone confirm the spindle size on these cranks as I dont have the tools to remove, is it 24mm or are they different?
Posted : 30/07/2021 3:26 pm
I forgot to add the cranks are original and the current BB is SRAM GXP
Posted : 30/07/2021 3:30 pm
Then it’ll be a GXP axle. 24mm at one end, 22mm (iirc) at tother. Adapters are often available for regular 24mm bbs
Posted : 30/07/2021 3:41 pm
Hope 24mm with GXP adapter will work, quite like Uberbike too.
Posted : 30/07/2021 4:04 pm
