Sram rival 22 chain...
Sram rival 22 chainring sizes, sizing down
4 Users
I've currently got a crosser with 34/50 cranks and 11-32 cassette id ideally like to run a smaller set if chainrings I just found out my crank has a 3 bolt removable spider and different ones are available if I manage to find rings to suit is there any reason why a 28/44 crank won't work as it'll still be a 16t jump, also can i run mtb 10 speed rings on an 11 speed road set up
Thanks in advance
Posted : 28/06/2023 2:26 pm
 5lab
28/44 would work fine, its actually a (relatively) larger jump between the two, but with a massive (for 2x) 11-32 out back, it'll be fine.
10 speed rings will work fine on a 11 speed chain afaik
Posted : 28/06/2023 2:50 pm
Ta
Posted : 28/06/2023 3:07 pm
correct. But not the other way round. Inner chain dimensions are the same but 10sp chains have thicker plates so foul 11sp cassettes
Posted : 29/06/2023 11:44 am
Cheers mate
Posted : 30/06/2023 3:12 pm
Watch out when buying for the pin that stops the chain dropping down between the chainring and the crank. Some aftermarket rings have this differently oriented as I discovered.
Posted : 30/06/2023 3:21 pm
