SRAM mech question
[Closed] SRAM mech question
Anyone know if there's much difference between X9 & X0 rear mechs apart from the cage material?
Andy
(Usually subscribe to best-shifters-and-cheapest-compatible-mech approach but have successfully bent an X0 mech...)
Posted : 15/06/2011 5:54 pm
My X9 rear mech has been through the wars - you can tell by the considerable scarring. Have bent them in the past but never broken one. I did however manage to blow apart the carbon cage on an X0
Posted : 15/06/2011 6:17 pm
well it is better made with better parts so it is better.
It is possible to fix /service an X0 one especially the all alloy cage version.
Do you mean can I tell in operation then the answer is no
EDIT: where how have you bent it? if it is alloy you can remove the bottom cage and vice fix it IME. X0 shifters do shift better , smoother and more gears up than X9 ones if that helps
Posted : 15/06/2011 6:27 pm
Think I've bent the axle the cage rotates on (cage looks relatively straight); had an off on the ice in Jan (which also bent the mech hanger - now replaced).
Have X9 shifters; if/when I go 2x10 I'm planning to get X0s, but it's a bit hard to justify them until something serious breaks or it's new bike time.
Andy
Posted : 15/06/2011 7:43 pm
You may be able to buy a replacement cage but before you do, check you haven't cracked where the cage axle fits into the mech.
Posted : 15/06/2011 7:50 pm
Just gone 2x10 speed
Was thinking about X0 but decided X9 rear mech ,X9 10 speed shifter saved over £80 for a pesky 10-25grams
IMHO not worth it.
Works the same as usual Sram as always had Sram,never missed a beat even all S***TED up.. 😀
Posted : 15/06/2011 8:20 pm
