SRAM Maven Lever bl...
SRAM Maven Lever bleed fitting only?
[#13535152]
Hello all,
Anyone know if it's possible to buy just the part that connects the syringe to the Maven lever on its own? I have plenty of syringes/hoses etc so don't really want to spend £20+ on a bleed kit for the sake of one tiny fitting. Searching only seems to bring up the bleeding edge part for sale on it's own which I already bought before realising I also needed the sodding lever end.
(I do have a SRAM kit but it's old AF and contaminated with DOT fluid).
If they weren't so ****** good I'd happily have kept using my Shigura's!
Thanks!
Posted : 15/04/2026 8:59 pm
The threaded end is the same I think dot or mineral, it was just the bleeding edge port which was bigger, just use one from the old bleed kit.
Jsut give it a blast out with some brake cleaner then maybe an airline. Wouldn't sweat it regards cross contamination.
Posted : 15/04/2026 9:24 pm
