SRAM guide brakes w...
[Closed] SRAM guide brakes with Hope discs
hi
I am trying to set up Guide RSC brakes with Hope adapters and 203mm front and 180mm rear Hope discs
doesn't seem to work without rubbing
can i use the discs with other adapters (Avid) or do I also need Avid discs?
thanks
Posted : 12/08/2015 11:44 pm
I'm pretty sure you need to use sram/avid mounts and rotors that aren't floating, that was what I was advised when having a set of guides fitted a few days ago.
As far as I am aware, you're not restricted to just Avid disc rotors.
Posted : 13/08/2015 12:05 am
Odd, I use that exact disc combination with my Guide RS on X Fusion forks & Transition frame with no problems.
Posted : 13/08/2015 7:04 am
mattbee - what adapters are you using? I'm using Hope ones and trying to sort it with washers under caliper to move it out a bit
Posted : 13/08/2015 8:22 am
little bump for any more ideas?
I tried in the dark last night so couldn't see properly which didn't help
Posted : 13/08/2015 12:01 pm
Got a Superstar adapter on the back & a Shimano one in front.
Forks are 180mm disc minimum so it's a smaller adapter than I used on my Sektors.
Posted : 13/08/2015 12:22 pm
Resolved - it was the floating rotors hitting the caliper. Nothing a bit of filing couldn't sort out !
Posted : 20/08/2015 9:24 am
