SRAM eagle problem ...
[Closed] SRAM eagle problem any one experienced it?
Just a quick update my bike has just shattered its 4th Jockey Wheel the bike is 10 weeks old, new chain just fitted on its first free service so that can be ruled out. The bike was also found to have broken fork internals and the dropper jammed on the very last ride. Bike is fantastic but no faith in the Eagle gx rear mech has anyone had problems with the higher spec eagle? Or is it just the Gx?
Posted : 29/10/2017 9:47 pm
I have had my gx transmission fitted for a few months. No issues to report apart from it's a little noisy on the 50 and jumps off the 10 sometimes if I back peddle.
Posted : 29/10/2017 9:54 pm
Little bit worried having bought into gx eagle....
Did you use the red chain set up tool?
Was the shaped quick link on the right way matching the chain travel?
I had a look at the rear mech and the top jockey wheel doesn't have loads of clearance to the chain and nowhere for it to catch IMHO.... Very little float either.
Posted : 29/10/2017 9:57 pm
A bit of an update from me, having had the bike back, the mechanic did actually confirm that the mech hanger was bent.
New hanger, new mech and even though i have only had one ride on it since, it was shifting very well and is still in one piece..
I will probably head back down to the fod this friday and see how it behaves.
Posted : 30/10/2017 7:41 am
I fettle my own bikes but I have never seen a derailleur be so sensitive to the hanger. I have a hanger tool as well but even with the best straightening I could manage the big rings remained a mess when shifting. When I examined the old hanger it was off by maybe a couple of degrees from straight in comparison to the new one but I am sure any other derailleur would have coped. It's also extremely sensitive to the B-limit setup. i'm assuming due to everything just being slightly narrower.
Great when it's working well though! Just hoping I don't go through several hundred derailleur hangers to make it so!
Posted : 30/10/2017 9:31 am
Bike went in to the shop today, the frame had been checked previously for alignment and the hanger there going to re check the frame, hanger and the gear shifter to see if there's a tension problem although it would mean it's intermittent and that would be a mare to find. I've been promised no matter what it's going to be fixed as I have mentioned rejecting the bike.
Can I ask every one the following questions to find a possible link;
1. Make and type of bike
2. Age/miles when failed
3. What type of trail were you riding when part failed
4.are you clipped or flat and shoe size
Thanks inadavance
Posted : 31/10/2017 6:14 pm
5. How quick did a replace the fail?
Posted : 31/10/2017 6:16 pm
Whyte s150s
3 weeks 1st time but average is 5 rides.
Red route, not that ruff but a few jumps
Flat size 12 five tens
From very next ride to 10 rides
Posted : 31/10/2017 6:19 pm
Whyte 909
Failed 1st ride 17 miles in.
Failed 2nd ride 17 miles in.
Survived 3rd ride.
Both times i was riding the top part of Launch Pad @ FOD, is that a blue??
Clipped in, size 10.
Posted : 31/10/2017 7:17 pm
There's a new hanger just out for the Eagle read into that what you will, the hanger will space the upper jockey wheel further away from the cassette.
Any more profiles would be much appreciated
Posted : 04/11/2017 10:45 am
Had this happen to me yesterday. Riding through sloppy mud, cranks suddenly locked and then a crack. Rear mech got pulled into rear wheel and ripped a spoke out, damaged a couple of others. Chain had got wedged between lower jockey wheel and cage. See here:
[url=
Been riding it for a few months. I had noticed the cage near to the upper jockey wheel does get very close to the spokes in the 50t. Annoyingly i only just bought a new groupset for another bike as i'd been really pleased with it.
Posted : 14/01/2018 2:21 pm
Well back on this thread posting again. After a couple of exploding X01 mechs which after various arguing and delays were replaced under warranty. As a stop gap I bought a GX mech which I fitted in Aug and has been running fine until today when the gears started to jump around and thought some TLC may be required. Further on in the ride I had the same as reported on may occasions including from myself where when descending on rough ground in a low gear the drivetrain would lock up. I now know to stop pedalling IMMEDIATELY otherwise the top jockey wheel would shear off, not great when your having some great fun blasting down a descent you earned after some hard earned pedalling to get to the top of the hill. Hopped off the bike, turned the cranks by hand and it seemed to sort itself out. The third time it happened I had a closer look at the bike and the chain was off the top jockey wheel. Got the bike home and on closer inspection there is so much play in particularly at the top but also the bottom wheel its frightening and the inner cage had been chewed quite a bit from the chain jumping off. Compared this to a new X01 I had in the garage and that has no float at all. Not sure if the jockey wheels on these mechs are different specs but the GX ones are wobbling a lot after 4 months riding. Although you shouldn't need to, if you could buy replacements for £20-£30 I wouldn't mind so much but I can't find replacements anywhere. So the option is to buy a new mech every 4 months because your jockey wheels are goosed, what a joke SRAM, you should be ashamed of yourselves. Price drop on GX mechs £70 so annual spend on mechs £210 due to some very premature wear on some plastic wheels.
Posted : 14/01/2018 10:42 pm
First of any in my Google search
https://www.probikeshop.com/en/gb/sram-gx-jockey-wheels/119866.html
Posted : 14/01/2018 10:49 pm
Is this happening on hardtail too or is it limited to bikes with chain growth i.e full suspension?
Posted : 14/01/2018 11:07 pm
Anyone got a link for the jockey wheels that are non SRAM? Preferably the 'pimp alloy ones'?
Ta
Posted : 15/01/2018 11:44 am
Anyone work in the trade able to shed some light on this, how wide spread is this issue? If you sell bikes with GX Eagle on, how many are coming back with an issue would be a good indicator?
Posted : 15/01/2018 3:21 pm
One admittedly filthy ride and this....
Unimpressed. 1 ride old. Seized rigid.
Posted : 15/01/2018 7:34 pm
For info, I tracked my issue down to the top jockey wheel seizing solid. I pulled it apart and it was solid with dry dark mud. Cleaned it out with pick and degreaser. Re greased and it works fine now. How long it will last we will see .Its been on my bike since October.
I message Uber Components asking if they were doing replacements. They are bringing out Jockey wheels a months time.
Posted : 22/01/2018 3:24 pm
ive been using aftermarket ones since my stock x01 eagle had more slack than a prozzies VAG..........
however, I still do occasionally get this issue even on ones with no play, so I'm really not sure what the culprit is, yes its much better, but its not totally eliminated it for me, I had an instance where I hit a jump about 3ft high at weekend, landed started to pedal and it started to do it then, I spotted it and pulled the chain out of the inside of the lower jockey.....
but its happening no where near as often as when the original ones had a lot of play....
I'm still non the wise how its happening, I'm guessing as it lodges on the inside of the lower jockey, the play does have some effect on it, but also wondering if the gap between the cage and inner side of the jockey is too great allowing it to fall in....I guess if it was closer theres no way the chain could fall into it....
Posted : 22/01/2018 4:30 pm
@ Oscillate Wildly
Don't suppose you have a link to the ones you bought?
did you keep with the 14 tooth & 12 tooth cogs or just go 12 12?
Posted : 22/01/2018 4:34 pm
@Slacks- exactly the same as mine in the post above yours. Seems they’re not greased from the factory.
Posted : 22/01/2018 4:59 pm
@rustymac got em from a Ukraine compmany called ka engineering...took about 3 weeks to come around 50 quid, didn't have an option at the time.....its almost as cheap now to just buy a spare gx eagle mech tbh.....
the kaengineering ones are properly made for eagle, so 14t, I'm not 100% sure but I cant really understand why a 12t one wouldn't work tbh, I really cant.....If I had some spare 12t ones Id happily test them out but I don't even have a old mech with any on...give it a shot, if you do and report back
I did email uber a while back and they told me a month or so away, that was probs 5 months ago haha
Posted : 22/01/2018 5:07 pm
Think I might pack mine with marine grease before I fit them.
Are the KA engineering ones on bushes or bearings?
Posted : 22/01/2018 5:12 pm
chilled - I replied to your msg last night, sorry about the delay Id only just seen it...
yep bearings are In, the top one is totally solid some 4 months on, but the lower ones got side to side play, ive tried repacking the lower to stop it but its not made any difference....I wont buy them again, 4 months isn't particularly great, so when these are shot ill just buy a new rear mech and keep it spare, unless some cheap jockeys come out in the mean time
Posted : 22/01/2018 5:15 pm
I was wandering if the bearings are replaceable?
Posted : 22/01/2018 5:22 pm
Not sure bud, they are alloy the actual jockeys and have hardly a mark on them, so if they are then its great, ill msg them see If I can get an answer...
Posted : 22/01/2018 5:26 pm
well mines is still getting stuck in the outside of the lower jockey wheel, done it a few times yesterday, really is pants! not even over anything really bad either, just gets stuck so you have to stop everytime it happens, otherwise you obliterate the whole mech! jockeys have lots of play again so assuming its this
is their a fix or has anyone figured out a solution?
Posted : 26/03/2018 12:41 pm
So i'm now having an issue with my GX mech, basically the chain is jumping off the top jockey wheel.  Especially when its muddy.  Whats the recommended fix?  not sure its a warranty issue just yet?  I have been having some shifting issues of late.
Any easy bodges or advice?  i really dont want to have the mech implode on me!
Posted : 26/03/2018 1:03 pm
well I'm getting some gx eagle wheels, my after market ones were just as shite as the others in the end, and with terrible communications etc so I cant recommend the after market ones from ka engineering, they lasted 4 months until lots of play on the lower
sram ones are only 30ish quid and are available now, I'm gonna bang a new chain on to so combined with them and new chain it should be like new
will see how it goes
Posted : 28/03/2018 11:52 am
Replace the bearings with some that have proper seals and decent grease. The sram bearings are pathetic, 500miles and the jockey wheels in my eagle x01 are shot. On the flipside the GXP bottom bracket is holding on in there, was expecting that to have gone by now.
http://www.peterverdone.com/making-a-dollar-out-of-fifteen-cents-2/
Posted : 28/03/2018 12:16 pm
where can I buy replacement bearings for them? can you press them and out I take it?
I guess the extremes of the mech movement are causing them to wear excessively, this set I'm gonna take the caps off first and put some extra grease in I think
Posted : 28/03/2018 12:21 pm
I’ve not had this issue with mine in about 6 months. However I really do have an issue with the way the chain drops in mud, especially the sticky Cotswold type. The narrow/wide chainring makes it difficult to replace in sync as well.  I also regularly feel the chain skip on the cassette which puts it out of sync.
Am I right in thinking earlier versions has narrow/wide on both jockeys as well which caused problems but now only on the lower?  Could this be the issue discussed here with the chain getting out of sync on the lower jockey?
My first SRAM groupset after years of Shimano and frankly I wish I’d bought the cheaper model with Shimano 11sp.
Posted : 28/03/2018 1:26 pm
I think all versions of eagle have narrow wide on both jockeys, mine certainly do, unless somethigns changed that's on a x01 mech I had when they very first came out
there was suppose to be a revision so I was told as they are aware of the problem of it getting stuck, but ive not seen any evidence to suggest a fix has been made common knowledge
ive had it drop off the front off mud clog (we don't even have much claggy mud here, just wet!) a few times, nothing major but it has happened
Posted : 28/03/2018 6:24 pm
I don’t think my issue is anything to do with bearing wear...so to speak it’s that the chain can fall off the jockey wheel into the gap between the teeth and the cage.  I see uberbike are making eagle replacement jockey wheels with ceramic bearings soon anyway
Posted : 28/03/2018 10:09 pm
Hmmmm...
Not a great tyres to read as I rebuild the Jeffsy with a GX Eagle drive train.
Going to take the jockeys off and pack with a good quality grease.
Can't believe the pic above! One wet ride and they look like that, must have been no grease in it at all?!
Posted : 29/03/2018 12:02 am
Just an fyi.
My few weeks old GX Eagle mech has NOT got n/w teeth on the upper jockey.
I believe this is different to earlier ones then?
Posted : 29/03/2018 12:51 am
As with Poopscoop, my GX Eagle mech has narrow/wide furthest from the cassette and symmetric nearest. Bought from Winstanleys on 14 Feb.
Posted : 29/03/2018 9:37 am
kinda related: I just ordered some 11speed 12tooth Uber jockey wheels for my SRAM GX mech over the phone, the guy told me they dont make the teeth on either narrow wide anymore as it doesnt do a lot.
The jockey wheels arrived are normal straight tooth looking.
Posted : 29/03/2018 10:10 am
russyh - I disagree, when they have that much play in the bearings, and a load of side to side play, theres every chance when you go over rough ground (as the chain jumps/moves around) that the chain will bounce off and unfortunately due to the play, allow more of a gap one side for the chain to fall down into...I'm pretty sure that's whats happening on mine on the lower one for sure
ive just picked up some new gx eagle jockeys, so will see what happens this weekend
Posted : 29/03/2018 10:36 am
See thats the thing.  I dont have play in my Jockey wheels and the bearings are fine.  I also dont have a Narow wide top jockey wheel? Just the lower.  I have found that if there almost appears to be enough space for the chain to fall off the top jockey wheel and get caught by the cage (see photos) i can imagine with excessive bearing play this will be lethal as the gap will widen.  I think i'm going to order some uberbike eagle jockey wheels as soon as they are in stock.  Will chase them up now.
Posted : 29/03/2018 10:47 am
Scrap that i have my problem sussed!!!  It appears the top Jockey wheel retaining bolt has come undone!!  God knows how its all still there!  You can see from the images!  Not sure how that has happened. There is thread lock on the bolts!  hopefully thats fixed it for me
Posted : 29/03/2018 10:52 am
right check this out!!!! my brand new genuine eagle jockey wheels
[URL= http://i1283.photobucket.com/albums/a551/oscillate_wildly1/20180329_095302_zpsfe6qmetb.jp g" target="_blank">http://i1283.photobucket.com/albums/a551/oscillate_wildly1/20180329_095302_zpsfe6qmetb.jp g"/> [/IMG][/URL]
the old ones that replaced and any pic I can find on google, DO NOT look like this on the lower one? it appears now that bigger lower jockey wheel has got a lip of plastic all the way around? maybe this is the fix that would stop allowing the chain to fall down the side of the jockey wheels????? it protrudes out meaning theres no/less space for the chain to fall into?
could be the simplest fix ever, unless anyone else eagle mechs have this lip on them?
Posted : 29/03/2018 10:59 am
this is a side view of it- you can  see the plastic lip protrudes all the way around the lower, meaning/hoping that the chain has no space to fall down?!
[URL= http://i1283.photobucket.com/albums/a551/oscillate_wildly1/20180329_100108_zpshylt8r5w.jp g" target="_blank">http://i1283.photobucket.com/albums/a551/oscillate_wildly1/20180329_100108_zpshylt8r5w.jp g"/> [/IMG][/URL]
Posted : 29/03/2018 11:03 am
Where did you source those?
Posted : 29/03/2018 12:01 pm
Pics broken mate, could you pm me a link? Or via email?
Will compare to my new GX Eagle...
Posted : 29/03/2018 10:58 pm
Well check my mech later. Here's your pic for others to see....
Posted : 29/03/2018 11:07 pm
Just checked my GX Eagle mech, it does NOT have a jockey like that!
You have a new design there and I agree with  you're reasoning on the design change.
Could you share the link please, from where you got them, Just so we know for future reference? 😃
Posted : 29/03/2018 11:46 pm
They look identical to the jockeys I have. The bearings seized up and locked the drive train.
Has anyone tried to replace the bearings? I found this article:
Posted : 30/03/2018 12:11 pm
I got them from my lbs who says they are readily available from distro
Big ride today no other change other than the jockeys abd it didnt do it once!!!!!
Every mech eagle wise ive seen has not got the lip around the big jockey wheel. None in the shop have, can you check again see if its got a protruding plastic lip all the way around?
Its definitely a new design compared to all other eagle jockeys ive seen i put it side by side to my old one and its 100% different, theres no where now for the chain to fall off the jockey the lip all the way around stops it from happening
Posted : 30/03/2018 8:03 pm
Have just had an Eagle groupset delivered. I am about to send it back in part because of the comment here. I would prefer reliability over range of gears- would I be best to go for GX 11 speed? There is almost no price advantage in doing so, as I got Eagle with cranks for under £300.
It is cheaper for me to go with Shimano 11 speed, but I here mixed reviews.
I am sorry for you all to hear all the problems being experienced here - my old 9/10 speed gear has always worked ok.
Posted : 30/03/2018 8:04 pm
<div class="bbp-reply-author">Oscillate Wildly
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">
</div>
Hi mate,I know it's very dependant on the shop, but how much were the jockeys? 😃
Gribble, I wont be sending my groupset back personally. The way I look at it, most people evidently don't get this issue. Think of how many oem groupsets are out there and working fine?
However,I will be getting the new design jockey wheels for it at some point as I can see how it "should" stop the chain getting wedged in the cage.... Anyway,I ride the North Downs and I simply don't ride massively gnarly stuff likely to make the chain drop.
Your other option is to get the E13 (9-50t) cassette and mate that to an 11spd drivetrain for even more range than the Eagle.... I thought about it but some say the E13 cassette didn't shift as well as shim/ sram.
Posted : 30/03/2018 8:39 pm
Think they were 35 rrp so not too expensive they are the gx version
Last 3 or 4 rides its happened to m4 a few times
Today not once with no other change
When you look closely now its all fitted i really cant see how its remotely possible the chain will get wedged in the cage at all it has no where to go
Posted : 30/03/2018 8:45 pm
Cheers mate.
I'm going to order some online and see if they are the new ones.... If not, send them back,at my costs obvs...
Posted : 30/03/2018 9:01 pm
Found them!
New shape:  https://www.sjscycles.co.uk/gear-spares/sram-gx-eagle-pulley-kit-for-rear-derailleur/
Ordering. 😉
Posted : 30/03/2018 9:08 pm
Thems the ones 🙂
Posted : 30/03/2018 9:29 pm
Cool, will sell mine on eBay. 😉
Posted : 30/03/2018 9:36 pm
@gribble:
wise decision!
It appears to me that SRAM skipped the "testing part" for the 1x12 design. The bikers are the tester right now...
My biking pals: the 1x12 bikers tune all the time on their 1x12 drivetrain. Would drive me nuts...
Posted : 30/03/2018 10:17 pm
All well and good with the new jockey wheel design but won't the bearings still be made of cheese. This is thread amongst the other reports of issues has really put me off Eagle, I'm not sure I can be bothered with the faffy set up, and a Sram XD driver either. Happy enough with my idiot proof and unfussy SRAM gx/sunrace 46t..(and hope jockey wheels)
Posted : 30/03/2018 10:53 pm
Going to pack the jockeys with waterproof grease and I've also ordered some bearings which I can press into the the jockeys if they get really bad.
The bearings are much cheaper than new jockeys...
Posted : 30/03/2018 11:31 pm
I’m buying the uberbike ones with stainless bearings once they release the eagle specific ones later next month.
XD drive is far superior in my opinion (and it is just an opinion) to Shimanos splined system.  Also I don’t find Eagle faffy to set up, my only issue has been with a loose jockey wheel all now sorted!
Posted : 31/03/2018 12:15 am
I've always been a Shimano man. Today I have just ordered my Dream bike with Eagle X01. I will be looking carefully upon delivery to check if this new flanged lower jockey wheel is fitted as standard.
Posted : 31/03/2018 12:57 am
I'm betting it won't be fitted with the new one to be honest. It looks like these jockeys have only just hit the retailers.
My GX mech was bought just a few weeks ago and has the older ones.
That said, you never know!
Posted : 31/03/2018 1:33 am
Poopscoop - reference your earlier comments about not sending your GX back if you were me, in your opinion is the only issue with GX Eagle the bad jockey wheels?
if so, I will just order some Uber bike ones from the start and bin the original set. Am living in a world of confusion and not sure what is the best way to proceed...
Posted : 02/04/2018 12:39 pm
Gribble just keep the Eagle . If you try to find bad reviews about anything you will find them . I know quite a few people with Eagle and they all seem to love it . I'm seriously considering a Trek Fuel EX 8 which they sell for the same price with Eagle or XT  which bizarrely has 2 x 11 and I will definitely go for the Eagle equipped version .
Posted : 02/04/2018 2:14 pm
wrong topic again, but my uber SRAM jockey wheels arrived for my 11speed set up and they look lovely and the bearings feel nice with no play. When I removed the old ones they had so much side play it was unreal!
Posted : 03/04/2018 10:20 am
I checked. I was incorrect about my jockeys there weren't the new type.
I ordered two sets of the new ones from SJS over the weekend. Just had email to say they don't have stock and SRAM say it will be May before they have more . 🙁
Posted : 03/04/2018 12:45 pm
https://singletrackworld.com/forum/topic/12-speed-eagle-better-than-shimano-11-speed-which-way-to-go/
Just for a bit of balance Gribble , here's a thread currently running .
Posted : 04/04/2018 2:17 pm
Got the new design jockeys arrive from SJS today. The design is definitely there to take up space in the cage so the chain can't get wedged.
If it isn't then I see no reason for it being there.
Posted : 04/04/2018 9:23 pm
EDIT: Token amount of grease in the bearings, so topped up with marine grease.
Posted : 04/04/2018 10:00 pm
[url= https://s18.postimg.org/kzk6tfr6h/IMG_20180404_205300.jp g" target="_blank">https://s18.postimg.org/kzk6tfr6h/IMG_20180404_205300.jp g"/> [/img][/url]
Posted : 05/04/2018 3:15 am
Ramsey - thanks. I saw the other thread. Have kept my Eagle and m going tin be putting the rest of the entire kit I need for the build.
Appreciate all the advice.
Posted : 05/04/2018 9:27 am
poopscoop! way better, see what I mean by theres no where for the chain to fall now?
what ever you've read on this thread gribble about eagle don't be put off, this is literally the only issue ive had on mine now in well over 1 year of full on use! its never missed a beat bar that, which seemingly it looks like they have sorted with a simple lower jockey change!
Posted : 05/04/2018 10:02 am
That's for the PM Oscillate.
Glad to hear it survived the ride you mentioned without issue!
Bodes well. 👍
Posted : 05/04/2018 7:42 pm
Bodes well. 👍
Posted : 05/04/2018 7:43 pm
So I’m having a new problem now!  Down shifting has become incredibly slow.  I have changed the inner and putter cable, which is now running beautifully smooth, cleaned lubed everything and greased Jockey wheels, reset mech indexing, B tension etc.  Oh and replaced mech hanger.   It’s like the spring is too weak to pull the mech back down when cable is released.  Very annoying, not least as I think warranty replacement will take a few weeks.  Any advice as to what might be going wrong?
Posted : 22/04/2018 9:25 am
Just bought the "trigger upgrade" kit (group set minus cranks) from bike-components.de and it came with the new jockey wheels, which was a pleasant surprise.
Posted : 22/04/2018 9:35 am
Sticky derailleur pivots?
I clouted one once that just made a pivot tight but was otherwise dead staright and in line.
Posted : 22/04/2018 4:31 pm
Just shore the bolt off the top jockey on my Gx 12spd yesterday on Snowdon.  Thankfully it didn't happen on lap 1 with a load of climbing left! I'd still be walking back now I think!  It had been running fine, shifting perfectly through a South Wales winter then the first sunny day and it explodes.  Is it possible they don't like the sun?! Anyone had any joy with warranty if they've changed the design? It's only 6 months old.
Posted : 22/04/2018 6:25 pm
Might be worth a shot if you bring up the fact that the new ones are distinctly different to stop the chain wedging in the cage.
That said, did yours explode because the chain jammed in the cage?
Posted : 23/04/2018 12:40 am
It may have done, was rattling down Snowdon at the time and felt it jam up, then next thing chain is off, roll down a bit past the rocky stuff to stop and see top jockey wheel has gone.
Shop I got the bike from have suggested returning to Sram, so fingers crossed.
Posted : 23/04/2018 8:19 am
Page 2 / 3
