The SRAM DUB BB on my Solaris Max has gone all stiff on me, not impressed with its longevity.
First time with an SRAM groupset. Can I fit a different brand, like a Hope BB?
Thanks
Gxp on the road bike was so bad i bought a 105 crank and swapped to shimano.
The mtb came with xx1 so planning to get hope BB (needs a 10 quid adapter) when the sram dies.
You can use a hope 30mm bottom bracket then use the hope dub conversion kit
SRAM bottom bracket advice
Avoid
Life is too short
Buy any nonSRAM/Truvativ chainset and bottom bracket
https://www.ceramicspeed.com/en/cycling/journal/launching-sram-dub-compatible-bottom-brackets/
https://www.ebay.co.uk/itm/Hope-29mm-DUB-Bottom-Bracket-Conversion-Kit-1-BSA-PF46-/163519783970
https://www.hopetech.com/_repository/1/documents/29MMBBCONVERSIONKIT2-Issue002.pdf
https://www.18bikes.co.uk/hope-dub-bottom-bracket-conversion.html
"Can I fit a different brand, like a Hope BB?"
https://www.hopetech.com/product-documents/drivetrain/
Thanks all for the advice. Will give the Hope BB a go.
