SRAM 9sp Powerlink ...
[Closed] SRAM 9sp Powerlink on a 10sp Shimano Chain - will it work?
I'm guessing not, so will I have to use the Shimano joining pins?
Posted : 03/09/2010 10:27 am
Will be down to the width Shirley?
No, use a KMC joining link instead: http://www.probikekit.com/display.php?code=A0308
Posted : 03/09/2010 10:28 am
I asked a while ago. The answer was a definite "don't try it, it doesn't work"
I bough a KMC 10 speed power link instead.
[url= http://www.edinburghbicycle.com/ebwPNLqrymode.a4p?f_ProductID=7059&f_SupersetQRY=C186&f_SortOrderID=1&f_bct=c003154c003151c007921c003208 ]Like these only the price seems to have gone up[/url]
\edit - BOOM, beaten to it.
Posted : 03/09/2010 10:29 am
10 speed SRAM powerLOCK is what you need young man. It does exactly what it says and therefore isn't a QR to break the chain again.
Posted : 03/09/2010 10:31 am
Can't see why not although it will obviously be slightly loose as it's wider. Really depends on the spacing of the cassette but as I've run 8 speed chains on 9 speed cassettes and vice versa without a problem it should be ok.
If it's not you'll soon know ๐Ÿ˜‰
Posted : 03/09/2010 10:33 am
Cheers all - thanks for the link to to the KMC alternative.
I did it to get my home, made a few funny noises in the highest gear, but did a job
Posted : 03/09/2010 10:46 am
KMC joining link is fine. Pretty sure that the Sram 10spd Powerlock is not re-usable.
Posted : 03/09/2010 12:42 pm
