Looking at upsizing my front rotor from 180mm to 200mm. Seems the generic / Shimano adapters (which are cheap and i’d normally buy) available are 203mm, whilst the 200mm ones I can find are SRAM specific and about £18-20.
Is a 203mm one going to be OK (I assume the pads will wear funny as not contact fully) or does anyone know of an alternative source for a 160-200mm post mount adaptor?
https://www.chainreactioncycles.com/lifeline-disc-brake-adaptor-post-to-post/rp-prod155580
I’m doing the same as you at present and saw this.
Looks good thanks, may need to consider where to get some longer bolts too as none included.
Check out Planet X for brake mounts & bolts, I’ve always found them to be cheap & if you do some rummaging about you’ll usually find what you need.
I managed to get Ti mounting hardware for mine for peanuts too.
https://www.planetx.co.uk/i/q/BSSDBM/sram-disc-brake-mount-adaptor
https://www.planetx.co.uk/i/q/BSDBBTHK/sram-disc-brake-bolt-torx-hex-key-interface
