Sram 11 speed drive...
[Closed] Sram 11 speed drivetrain very noisey
Hi
I bought a second hand bike which came with the Sram XX1 drivetrain.
It was ok but the chain was stretched/elongated to .75.
Put a new chain on and the cassette slipped on the larger cogs, put a XO1 cassette on and it now works but makes a lot of noise even when it is not that dirty.
Any ideas?
Thanks
Posted : 04/01/2015 1:57 pm
When I fitted a new chain it was noisy on the worn ring, calmed down after a couple of rides. I'd have ridden what you had into the ground first though, rather than replace for the sake of it.
Posted : 04/01/2015 2:33 pm
You've probably already checked but make sure the upper jockey wheel is seating in the chain properly.
Posted : 04/01/2015 2:42 pm
njee, it was my plan to ride the existing chain/cassette to death but a broken chain put pay to that as it was then too short to work.
grobin I have ensured that the wide links are in sync with the wide teeth on the jockey wheels and the chainring. I will have a play with it and see if it can be fettled,I have found that everything needs to be just so to make it run smoothly.
Thanks
Posted : 04/01/2015 2:49 pm
Had the same issue with my XO1 but after a few rides it's gone?
Cassette seems to have bedded in
Posted : 04/01/2015 7:32 pm
I can't believe that a new block doesn't also need a new chain ring
Posted : 04/01/2015 8:06 pm
It's usually the chainring-we end up changing quite a few when the chain's are that stretched, won't slip, but slightly noisy & you can feel it feeding back through the pedals.
Posted : 04/01/2015 8:11 pm
I should take a look at the front chainring I think sram make them from cheese(philaadelphia) I think, my one is worn right out and is picking up the chain slightly even though the chain isn't at .75 yet. A new chain seems to have made it worse but at least the cassette is still ok!!
Posted : 04/01/2015 8:14 pm
My bets on the chain being run through the rear derallieur the wrong side of that little metal separation plate.......I bought a bike that had been set up with a newish chain...no wonder he thought it was noisy and hated the bike 😆
Posted : 04/01/2015 8:20 pm
Mine made allot of noise whenever I put some force through the pedals, the whole drive chain was new and 3 months old, in the end I replaced the front chainring as other was looking slightly worn. This solved it, I sent the one that came off to SRAM as a £65 chainring should last longer than 3 months of summer riding, they came back and said it looked fine to them... I find the wear vs noise timeframes are allot shorter with thick thin rings. Especially SRAMs own 11 speed. They are cheese.
Posted : 04/01/2015 9:50 pm
"A lot" not "allot".
Like I say, my chainring was noisy after changing the chain, particularly under pressure and in the larger sprockets, ie climbing. It settled down quickly enough though and is still silent, glad I didn't change the chain ring frankly.
Posted : 04/01/2015 9:54 pm
 rone
My x01 cassette/chainring setup and is noisy without fresh lube.
My other bike has an xx1 crank/ring and x01 cassette is defo less noisy.
Can't find anything more scientific than that.
Posted : 04/01/2015 10:25 pm
X01 cassette needs a few miles on it with a brand new chain, same as the RED road groupo. Worth doing front ring at the same time of course.
Posted : 04/01/2015 10:33 pm
Surely the chain ring wears out say 11 times faster than the cassette!!!
(Ok I might be exaggerating a tiny bit...)
Posted : 04/01/2015 11:36 pm
