Went to fit a BLACKSPIRE SNAGGLETOOTH 30 tooth in place of a SRAM 32. Looks almost identical except you can't actually line up the chain ring bolts !
Anyone had this problem and found an alternative 30 tooth option ?
Which crank? The higher end ones have an irregular pattern to allow changing the chainring without removing the cranks from the frame. Direct-mount rings should fit if your crank has a removable spider.
Sram are 94bcd is the Blackspire 96 bcd ?
If so you'll need to do a bit if filling to make it fit.
It's the X1, and taxi25, you could be onto something there. Did wonder about getting the file out.......
I don't suppose there is a SRAM fitting chainring around the £30 price range ? Is it like DELL computers ?
Oval seems all the rage.
http://www.chainreactioncycles.com/mobile/black-by-absoluteblack-narrow-wide-oval-single-chainring/rp-prod131089
works components doing direct mount oval for £25 at the mo
