Does anyone have any experience of the SRAM 1 x 11 road gears? The reason I ask is I'm using SRAM GX gears on my gravel bike but the derailleur's a bit clanky-clunky. I use it for mixed road, bridleway & gravel tracks (think CX Sportive only without 400 other people on the same route). I think the problem is the strong clutch spring on the SRAM 1x MTB derailleurs (necessary offroad of course). I'm wondering if I could instead use an Apex or Rival 1x derailleur. The big question is, will they work with an MTB (X01) shifter? The gravel bike has straight bars & I like it that way.
SRAM MTB and road were interchangeable. However I bet there was something that didn't match. I know some SRAM was set for shimano shifters.
Helpful? Nope
well, the cassettes certainly are... the 10-42 jobbie is the same across the board, so therefore the derailleurs should be.... shouldn't they?
the above is all theoretical you understand!
Have a force 1x11 road set up. Shifting is a little clunky compared to shimano.
Rear mech has a clutch though so guessing the mech is similar to what you curently have.
Older 2x road set ups I have are considerably smoother shifting. But the cassettes on my road set ups are much smaller range.
No. SRAM 1x11 MTB and 1x11 road have different pull ratios. You could use a 10-speed derailleur, either road or MTB (10 speed are both same ratio) but they're not rated to 42T rear. So really it's just the 11-speed MTB derailleurs that are available to you, unless you're willing to use a shiftmate or similar to convert the pull ratio on a 1x11 road der.
sixpotbelly - thanx, i thought that might be the case. i'm learning to hate sram. their mtb stuff seems really pricey compared with road, but isn't well made at all. i've had 2 (2!) x01 twist shifters fall apart on me. the gx shifter i have now is better, but the gx derailleur is very slow & clunky compared with road gears, so i was hoping the (affordable) rival might fit the bill, x01 & xx1 derailleurs being way beyond my budget. maybe i should just give up cycling & take up something cheaper, like golf or fine wines... 🙁
