Squirt lube - any g...
[Closed] Squirt lube - any good for winter conditions?
I think Squirt works great in dryish conditions but not really tried it in full-on grimness. It calls itself a dry lube, but I assume that means it dries on the chain rather than being a reference to suitable conditions.
Anyone got an opinion? ๐Ÿ˜‰
Posted : 04/11/2010 11:57 am
Based on my experience I'd say definitely not for wet riding. Tbh I've found that it sees just a hint of water & it disappears.
Posted : 04/11/2010 12:00 pm
I'd agree, I thought it was great initially, but even wet summer conditions saw it disappear within 30-40km. I wouldn't mind so much but its not exactly a lube you can re-apply on the trail.
It seems to last better on the road bike though, I did 70 or 80 miles in filthy wet conditions and the chain still seemed OK, not sure how that works?
Posted : 04/11/2010 12:25 pm
Its great in the dry, not too good in the wet.
Posted : 04/11/2010 1:42 pm
I'm on RnR extreme now..tried green oil the other day but the chain needed degreasing when I returned which I've grown to loath after using squirt over the summer
Posted : 04/11/2010 1:46 pm
The Scottoiler works OK. Fitting it can be fiddly, but its easy to use.
http://www.scottoiler.com/uk/products/scottoiler-bicycle-oiler-active-fluid-system.html
Posted : 04/11/2010 1:50 pm
Ran it all summer on two chains, probably built up a fair coat on the chain. An application just about lasted a lap at the rainfest that was D2D this year, but that was with no time to dry off after application. I'm not sure when lube needs reapplying- I apply before a ride, if the chain starts squealing before i'm done then it needs reapplying. Sunday, in the wet in Surrey it was about 15 miles. I'm sticking with it though- it's worth it for the clean shifting and drivetrain.
Posted : 04/11/2010 1:54 pm
 nuke
Personally I found Squirt pretty good so fair this Autumn/Winter. However the problem I have is that now the temperature has dropped, when I put it in it doesn't dry like it did in the Summer...I put it on the day before a ride and it's still milky white and wet the next day. Therefore switched to RnR Extreme
Posted : 04/11/2010 2:02 pm
Good for 1 hour in wet but any longer it does wash off - OK in mud but copious water does seem to wash it off ๐Ÿ™‚
Posted : 04/11/2010 2:04 pm
slight hyjack-R,n,R extreme is a great winter lube then..
Posted : 21/11/2010 7:43 pm
I did 3 hours today in rain from some swamp biking through the woods to a beachride and...well the Alfine drivechain was still smooth at the end and as mentioned the drivechain is just so clean after...
im sticking with it over winter as i think wear is reduced with it...
guess it all depends on where you ride and grit conditions? ๐Ÿ˜ฎ
Posted : 21/11/2010 7:49 pm
I can recommend Squirt highly...works amazingly well and seems to stick to my chain in all conditions...
Posted : 21/11/2010 8:00 pm
I wasn't impressed with it for anything other that dry conditions. Used R n R extreme and found it didn't last either. Going to go back to Finishline Wet or Pedros.
Posted : 21/11/2010 8:02 pm
Yep, very good, clean lube in the dry but does get washed off pretty easily in the wet. I've gone back to purple extreme for the winter.
Posted : 22/11/2010 12:35 pm
Muc Off Wet Lube... great for winter has to be tried to be believed:
http://www.chainreactioncycles.com/Models.aspx?ModelID=31093
Posted : 22/11/2010 2:02 pm
