SQUEEEEEEEEEEEEEEEE...
[Closed] SQUEEEEEEEEEEEEEEEEEL - please help me solve...
I've some old model Deores.
They have been gutless for a month of so, now squeal like a pig with its knackers caught on barbed wire.
So far I have:
- cleaned pads and discs with muc-off by tooth brush.
- sanded pads and discs
No change.
- changed pads for new Shimano's I had in the toolbox.
MORE squealing, less bite.
Even worse. Now discs and pads are coated in noticeable black brake dust / feel slippery to finger.
Suggestions as I am about to chuck on some new pads - could I have cooked discs? Maybe leaky pistons? Sintered Shimano are sh*t?
They are under warranty, but I am dreading Rutland's lack of interest...
Posted : 25/06/2018 11:19 pm
@Mods - should this be a sticky thread?
To match the leaky calipers?
Posted : 25/06/2018 11:28 pm
I've had this happen with a couple of different shimano brakes, usually the rear, I'm not sure what it is but I don't think there's a fix.
Posted : 25/06/2018 11:30 pm
^thats what I suspected. I have tried *everything* - had given up on some 5-6 year old ones that did this, but wondered if there is a new 'fix'.
Time to see if Rutland will warranty...
Posted : 25/06/2018 11:49 pm
Gt85 should sort it
Posted : 25/06/2018 11:56 pm
New rotors.
Ive had similar problem and new rotor fixed it.
Make sure u bed it in properly. Or it will glaze and squeal.
Posted : 26/06/2018 6:38 am
I had the same problem and the fix was to ditch the sintered for resin.....been ok since.
Posted : 26/06/2018 8:31 am
Could be leaking pistons in the caliper:
https://singletrackworld.com/forum/topic/help-my-brakes/
Posted : 26/06/2018 10:22 am
ime with shimano brakes is once the squeal sets in you need new rotors and pads. i had it once and i tried everything including dishwashering the disks.  i think the disk gets contaminated which contaminates the pads. never use a second-hand pad on a new disk.
Posted : 26/06/2018 10:33 am
Aye new pads and rotors. Worked for me anyhow. Think they just get to a point when they are unrecoverable. Particularly when the rotors looks discoloured.
Posted : 26/06/2018 10:36 am
Sounds like the leaking caliper/piston seal to me. Only option is to return them and get a replacement.I've had this happen to at least two sets of Deores now. When they die again I think I may just bite the bullet and get Hopes. The deores are great when they work but they seem to have a lifespan of about a year.
Posted : 26/06/2018 10:37 am
make sure all the bolts are tight on caliper and rotor?
copper grease on the back of the pads? I did this years ago on a set of Maguras and it worked.
rough up the surface of the rotor with a bit of sandpaper?
Posted : 26/06/2018 11:06 am
Check for leaks carefully first: If there is a leak in the calipers it will trash any new pads quickly. Do a quick clean up first then hold the brakes on firmly for a few minutes and see if any new dampness appears.
Posted : 26/06/2018 11:29 am
Go to Fort William and do an uplift day.
After one run my brakes were as bitey as they've ever been and completely squeal free
Posted : 26/06/2018 11:39 am
I had the same problem just recently and found a thread online suggesting cleaning pads thoroughly with hot water and neat Fairy liquid (rubbing pads together)... worked a treat !
Posted : 26/06/2018 12:52 pm
Posted : 26/06/2018 1:41 pm
I cleaned my rotors with cheap diet coke (i.e. brown phosphoric acid) to remove a layer of oxidation. I also tried sanding pads - no joy. New resin pads were OK though. To be fair I didn't do the control of new pads and no coke...
Posted : 26/06/2018 1:49 pm
I did manage to rescue my rotors after the dreaded leaky seal problem. I scoured them thoroughly with cream cleaner, rinsed with boiling water, then dried them in the oven. It's definitely worth a shot as it doesn't really cost anything apart from a bit of your time. The pads were junk though.
Posted : 26/06/2018 3:32 pm
OK, last chance. A new set of pads has arrived. Oven will be used tonight (that saved an old rotor many years ago for me) on the rotors.
Posted : 03/07/2018 11:37 am
Hmm good point about leaks. (Sorry OP for jumping in)
I have XT discs.  After the bike has been sitting a while they are squealy and weak. A good 20 minute thrash brings them back to life and they are fine the next day.  But they consistently return to squealy weak.  I also tried new pad/rotor (just on the back for diagnosis).  Leak sounds plausible.  On the other hand it seems strange that front and back seem to be affected in the same way and I haven't had to top them up or bleed in a few 100km aggressive riding.
Posted : 03/07/2018 5:26 pm
OP - did you try blowtorching the pads then giving them as little sand as well as dishwashering the discs?  That's worked for me in the past. BTW, I probably wouldn't inhale any of the smoke that comes off the pads!
Posted : 03/07/2018 11:59 pm
 pdw
twowheels I had exactly the same, including the same reasoning about why it couldn't be a leak (both went together, no obvious loss of fluid).
Stick a bleed block wrapped in a paper towel in them and pull the lever gently with a rubber band. Leave for 12 hours, inspect paper, replace under warranty.
Posted : 04/07/2018 9:04 am
Success, and an experiment....
Disc as is, quick clean and new non Shimano pads = great.
Old, uncleaned disc on non Shimano pad = great
Old Shimano resin pads on old spares disc = squeal.
New non Shimano pads on the spare disc = great.
Old, old Shimano resin pads on any disc = squeal.
So the running theme is that it is Shimano resin pads - both almost totally worn and about 10 rides old.... FWIW all other pads are either Uberbike or Clarks.
Posted : 04/07/2018 10:21 am
So we are back to squeeeling - both with clarks and uberbike pads.
I also have discovered they *are* leaking - oily film on edge of pad backing, on one end of caliper and on frame below....
I was about to click buy on a new set of Magura MT4's, when I then discover that I need thicker Magura rotor's and a matchmaker clamp thingie for my dafty Shimano integrated ispec whatever of the bloody three iterations it is....
FFS shimano.
Posted : 26/07/2018 1:42 pm
It will be the leaky o seal problem (although last time I mentioned that half the forum told me I was talking rubbish). I had a few calipers do exactly the same thing, no discernible loss of fluid but if the bike was left unused for anything over a week the brakes squealed like mad and had no power. 20 mins of hard braking seemed to cure it until the next time.
I tried everything, cleaning, sanding, new rotor, new pads, eventually always the same squeal.
Eventually I just bought some Magura MT2 and haven't touched my brakes since. I actually took a punt on some Chinese MT2 off ebay but they were spot on and came with new rotors. I sold my old shifter bought a used zee shifter with a clamp and sold the shimano levers.In all it didn't cost much more than £30. Money well spent.
Posted : 26/07/2018 2:07 pm
I am removing mine - a friend might have an old set I can borrow - and they are going back to Rutland for Warranty.
If they give me new ones, I am selling and buying Magura...
Posted : 26/07/2018 2:10 pm
Check the hose join to the callper - had a little leak there on the tripster that a clip of the hose and new olive sorted (new pads and a clean up too to be safe).
Posted : 26/07/2018 2:34 pm
Mine were smoking heavily after a pretty short descent which I've never seen before, but didn't squeal and stopped properly for the rest of the ride after. Few days later and they're back to squealing again! These are the very first 'good' xt brakes that I bought when they first came out 6 years ago or whatever so can't complain.
Posted : 26/07/2018 2:37 pm
Spray rotors with brake cleaner and put a match to it. (wear protective gear don't try this at home always have adult supervision keep out of reach of children etc.)
Tip from my LBS and stopped my Shimano road brakes from honking.
Posted : 26/07/2018 3:13 pm
It's back.
Last three rides I'm down on power and squealing again.
A few thoughts - a few rides before was Laggan, before that Ben Ledi. Perhaps I'm cooking pads or fluid or seals? See below for my pad (right) and Mrs_oab's on left. Both Shimano resin put in at same time...
https://flic.kr/p/2g4wUR7
So, do I dare go through the rigmarole and lies that is Rutland again or what...?
(Ps, we've four sets of Shimano in the household, three Deore and one Xt, before that three sets of SLX and XT. No issues until they were 5+ years old)
Posted : 28/05/2019 10:47 pm
 Yak
Got to be seals again. I don't know Ben Ledi, but I know Laggan and it's not an obvious brake cooking spot. Maybe clean it all up and if it goes again it's seals and you are back into warranty faff.
The backing plate on your pad does look dusty/oily too.
Posted : 29/05/2019 12:32 am
Have you tried the o-ring fix mentioned above?
Posted : 29/05/2019 7:48 am
They are new calipers.
Posted : 29/05/2019 8:08 am
It's a regular occurance with Shimano brakes, sometimes even on brand new bikes. A few years back, I bought XTs to replace ancient Hope Mono Minis rather than doing a full rebuild, two years, two levers, and four leaking calipers later, i'd gone back to Hope for a set of Tech Races, and been trouble free ever since. All the parts were warrantied, but the faffing and uncertainty of how long before it happened again made it worth the swap.
Posted : 29/05/2019 8:12 am
You should have sold them and gone for Maguras... 🙂
It does sound like you've been unlucky to get two bad ones in a row.
Posted : 29/05/2019 8:38 am
Replace Shimano with a brake manufacturer who can make seals that hold fluid in on a more regular basis I reckon. I’d be looking at Sram Guides or Magura MT5’s I think.
I’ve had one set of deore’s which were ok ish (but not wildly powerful) and they went all squealy and lacking in power with very little use so I sold them and bought a pair of Guide r’s off eBay for £80 with a bleeding edge bleed kit. Had been used a few times before being replaced by Hope as the guy preferred them. I know a few people who have had leaky shimano brakes too.
I am Magura curious though next time I need brakes
Posted : 29/05/2019 9:23 am
 poah
one of left looks normal the right not so much.
Posted : 29/05/2019 9:34 am
Was that not me Joe? 🙂
I've just sold the Hopes to try the new Shimano 4 pot brakes too! Fingers crossed eh?
Posted : 29/05/2019 9:55 am
Ah yes, maybe it was John, they’re still going strong on a different hardtail I’ve built. Now with uberbike race matrix pads in them they’re really good!
Not sure I’d sell Hopes to go to Shimano though......
Posted : 29/05/2019 10:28 am
I do think Magura is the answer.
Eldest_oab's new bike has them, add did some test bikes at the weekend. Great power, even better control. 5yr warranty.
Time to warranty these Shitmano's then and sell them as 'new'.
Posted : 29/05/2019 12:49 pm
A question - is it particular models of Shimano brakes that have this issue?
Upping calipers to 4-pot Deores is one option.
Other option is Magura MT4 or Trail Sport.
I'm keen to have new with warranty on this one...
Posted : 29/05/2019 7:39 pm
Sounds like you have done everything possible to sort this out . FWIW I had the exact same problem with Deore disc brakes front and rear at the same time on a bike . I kept changing pads , cleaning rotors but every time that I left the bike for a few days and jumped back on it the problem returned . 2 year warranty on them and mine went back and I replaced with SLX and the problem went away . I work in a bike shop so it was easy for me to upgrade it won't be an option that you can do probably . If you don't want to deal with Rutland Cycles any local bike shop will have a Madison account and will be able to handle your claim , albeit they will charge you unless you have a good relationship with them .
Posted : 29/05/2019 8:35 pm
Update - just had an email to say that Madison agree they are knackered.
Apparently they don't have any compatible calipers left ( 🤣🤣🤣 ) to replace them.
I'm getting an £87.50 refund....
TBF, the two year warranty is up in a couple of weeks.
Posted : 30/07/2019 10:30 pm
Magura MT5 time?
Posted : 30/07/2019 10:55 pm
I've already bought a set of Deore 4-pots....
Posted : 30/07/2019 11:03 pm
I used a chefs blowtorch to burn clean rotors and pads. Works a treat. Or at least did for me.
Posted : 30/07/2019 11:07 pm
That's great. Until the caliper weeps again.
Posted : 30/07/2019 11:12 pm
4 pots came with my new bike (6 months ago) went through all the above new pads sintered resin, Uber Shimano, new rotors but still screeched like a banshee wet or dry all that solved it was changing to Hope. Bike shop sent the 4 pots back to Madison which were replaced and I now have a brand new set which I’m reluctant to use and even more reluctant to sell. To note I have not had this with any previous Shimano brakes just the wandering bite point
Posted : 31/07/2019 8:18 am
Wandering bite point not being a particularly desirable trait in a brake either - a few times I’ve had a go on a mates SLX brake equipped bike and it’s scared the crap out of me when I’ve needed to brake and the lever suddenly pulls right to the bar and you have to let off and pull it again.
I’ll stick with my sram brakes that don’t do that - if they ever fail then Magura 4 pots are probably topping the list to try next.
Posted : 31/07/2019 9:22 am
