Square Taper Middle...
[Closed] Square Taper Middleburn Users.....Step Forward.
[#1355471]
I have long been a fan of the Middleburn cranks only selling my last pair before Christmas 🙄
I am looking at a set of new square taper Middleburn's for a Cotic Soul build.
I know Middleburn are now doing/about to do a through chainset but I still quite like the square tapers 😀
So then get em out and show me some square taper* lovelyness.
* ISIS also allowed......I guess 😆
Posted : 23/02/2010 9:38 pm
Posted : 23/02/2010 9:40 pm
Posted : 23/02/2010 9:42 pm
Thats what I'm talking aboot. 😀
Gurt lush.
What BB do you run?
Posted : 23/02/2010 9:44 pm
Oh christ, I saw a chainring and thought "wow, that looks awesome!" when I saw that second one bonesetter posted.
Think I need to get out a bit more (does look good though, doesn't it?).
Posted : 23/02/2010 9:47 pm
Posted : 23/02/2010 9:48 pm
What is that chainring bonesetter, can't spot it on the Middleburn site (now I actually looked for it, there is no hope at all).
Posted : 23/02/2010 9:51 pm
Square taper Middleburn's on 2010 Cotic Soul
Posted : 23/02/2010 10:00 pm
I suspect it's a Boone ti chainring or something similar.
I've had square-taper and ISIS Middleburns (no fotos and the missus has the camera on holiday just now), but the square-taper are the ones I've kept. Would maybe consider the newer model for my next bike but that won't be a while considering my new one only arrived last week 😀
My commuter has a set of RS2s on and was thinking of putting them on my soul you may have made my mind up. Just need to buy a new set of rings now. I wonder how much stiffer the newer versions are.
Posted : 23/02/2010 10:19 pm
Denis99 - Member
What length BB are you using?
Posted : 23/02/2010 11:00 pm
You'll need a 118mm width for the new (2010) soul - I originally fitted a 113mm - but it will foul the crank arms.
UN53 if it makes any difference.
Posted : 23/02/2010 11:05 pm
warpcow - Member
It is indeed a very, very beautiful Boone 🙂
Posted : 23/02/2010 11:12 pm
170 square tapers spinning on a phil wood ti BB...sweetness 🙂
Posted : 23/02/2010 11:15 pm
 JB
I've just fitted a set of Sq Taper RS8s onto my Cotic Simple (SKF Bottom Bracket), was advised to Re-torque (40Nm) after first ride... I did and it needed a good bit, but have done the same after every ride its had so far (about 6 times) and has needed a noticeable mount of re-torquing each time...anyone else experienced this?
Posted : 23/02/2010 11:17 pm
Yup, regular re-torquing required until they've bedded in(check Royce bedding in procedure for full details).
Posted : 23/02/2010 11:22 pm
hey Coastkid, did you get the bb for the pug from the states or does someone in the UK do'em?
sorry for the hijack.
cheers!
Posted : 23/02/2010 11:36 pm
Running on a Royce BB.
And creaked like a good 'un until properly bedded in, as stated above.
Posted : 24/02/2010 12:16 am
Square Taper M burns on both bikes here. Only now after 10+ years and 2-3 bbs has the old RS3 given up.. (the taper on the drive side arm!).Currently being replaced with an RS7.... Both running a Royce sq.taper, 109mm axel.
Posted : 24/02/2010 1:20 am
