Splitting Powerlink...
[Closed] Splitting Powerlinks How?!?
I know, just squeeze the sides of the link together, push and the powerlink cleanly and simply disconnects.
Does it F*ck!
Okay so the chain had been left covered in mud and water for a week so was rusted. I used a link splitter to get the chain off the bike and even after much cleaning and luing I can't get the b@stard apart.
any tips before I sling the whole lot out into the snow?
Posted : 03/02/2009 2:42 pm
ask your kid sister to lend you a hand?
They sometimes get a bit gunked up but other wise piece of piss to pop free.
Posted : 03/02/2009 2:44 pm
I found they split easier on shimano chains. I used one on a sram chain and could I get it off - could I buggery (and it was a clean chain too)!
careful, you'll get oil on your frilly knickers! ๐Ÿ˜†
Posted : 03/02/2009 2:45 pm
When you squeeze the two links together wiggle them side to side at the same time. I used to have the same prob until a guy a bike shop showed me how to separate them.
Never had a problem since.
Posted : 03/02/2009 2:49 pm
Get a toothbroosh and some petrol on it, give it a bit of a brush, re-lube and try again. And MTFU. ๐Ÿ™‚
Posted : 03/02/2009 2:50 pm
I reckon it might be the KMC chain then. Never had a problem before, I have the thumbs of Thor normally
Posted : 03/02/2009 2:51 pm
Smash it! Smash it with a hammer! That'll teach the **** thing to not open!!!
Stop!
Valium time...
Posted : 03/02/2009 2:55 pm
WCA - bear with me here, it's just a hunch
Can you post a photo of your fingers please along with something else for perspective?
Posted : 03/02/2009 2:56 pm
Soak it in petrol and set fire to it.
Squeeze together and flex it from side to side.
Posted : 03/02/2009 2:57 pm
This is what you want.
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=7781 [/url]
I use one all the time, but then I'm a sucker for tools.
Posted : 03/02/2009 3:00 pm
Wanders down the garage to look for some funny looking pliars
Posted : 03/02/2009 3:02 pm
When you've got it off, replace it with a Connex one. Much better design.
Posted : 03/02/2009 3:05 pm
Turn the opposite side topwise.....
I used to struggle with them as well but i found that rather than trying to squeeze it as hard as possible a lighter touch works better,,, and yes i am still talking about powerlinks ๐Ÿ™„
Posted : 03/02/2009 3:08 pm
Got the f*cker. definately the chain
Posted : 03/02/2009 3:09 pm
WD40 & a blow torch, what's the worst that....? ๐Ÿ˜‰
Posted : 03/02/2009 3:10 pm
WCA's hand
Posted : 03/02/2009 3:11 pm
Smash! Smash! Kill! Destroy!
Heh.
Valium not working today.
Posted : 03/02/2009 3:45 pm
Don't KMC chains have their own type of removable link?
Posted : 03/02/2009 3:56 pm
avdave - yeah but it disappeared behind the fridge a while back so I shoved an old powerlink in there
Posted : 03/02/2009 3:58 pm
Can you not try these. http://www.chainreactioncycles.com/Models.aspx?ModelID=7781
Since using these it is dead easy to remove the chain when I need to fully clean it and the chainset
Posted : 03/02/2009 4:05 pm
ERRRRR mywebsites^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Posted : 03/02/2009 4:12 pm
The joys of working from home!
So the real answer to your question is move the fridge.
Posted : 03/02/2009 4:13 pm
This is a great thread, or it would have been a couple of days ago. I ended up hacksawing one of the blighters off, and you know, the squeezing thing really does work. Who'd have known? No more swearing at powerlinks for me.
I was going to say that they should come with instructions, but if they had I clearly wouldn't have read them.
Posted : 03/02/2009 6:12 pm
Let's just hope when you come to open the gates for the event they're not locked with anything more complicated then a powerlink.
Shite was meant for the BBB thread.
Posted : 03/02/2009 6:13 pm
Has someone suggested using your teeth?
Posted : 03/02/2009 6:20 pm
