Howdy folks,
I've already broke one hex key trying to get the freehub off my halo spindoctor hub, any tips on how it should be done before i wreck the whole thing?
I've got the hex-key-in-a-vice trick going, but what sense is the thread? And what side of the freehub do you remove from (i.e. drive or non drive)?
Cheers,
Chris
Mine was a nightmare to get off. Used an 11mm hex key in through the drive side attached to a breaker bar. Mate of mine held the wheel while I swung from the breaker bar. Took ages to free but it finally loosened with a very loud "crack!" Spray some WD40 in there to help it out.
Good luck! Thread is normal (Anti-clockwise removal from drive side.)
Cheers diam,
Sounds like it'll help burn off a few Yule induced calories.
get some plus-gas in there!
