Spesh Enduro, CCDB air just back from TFTuned with nice new heavy duty mounting hardware.
For the life of me I can't squeeze the hardware back into the gap for the front mount.
Gap 21.6mm and hardware 21.9mm.
The frame is solid so no easing it in.
Any tips gratefully received, sun is shining and i've not been out for a fortnight.... getting desperate!!
Posted : 11/09/2015 10:41 am
stating the obvious but is it possible they've fitted the wrong bush in the eyelet?
Posted : 11/09/2015 10:55 am
The 0.3 mm is your problem, file the hardware down.
Posted : 11/09/2015 11:02 am
Can't you just scrape the paint of the frame?
Posted : 11/09/2015 11:05 am
Ok... it's in.
Thanks George.
Ok, so I filed a touch off the mounting kit.
Just a brake adaptor to be found and a tyre to get up tubeless and I am away!!
Posted : 11/09/2015 11:27 am
