Specialized HiLo 19...
[Closed] Specialized HiLo 190mm QR hub. Convertible to 197x12?
Help, oh help me STW, my google-fu is waning and specialized are taking their sweet time getting back to me.
I have:
[i]Specialized Hi Lo disc, alloy, sealed cartridge bearings, XD driver body, 190mm wide, QR, 32h[/i]
And I want to know if I can fit it to a thru axle frame with a change of end caps/axle, or is a shiny new hope fatsno in my future?
Posted : 07/01/2018 11:08 pm
[img] ?itemid=4664133[/img]
Anyone?
Posted : 08/01/2018 10:19 am
Its not a definite Tom, but I would wager that the end caps wil be the oly thing different. 190 on most fatbikes was QR, 197 is through axle or maxle... only the end caps on the sets of hubs I have, are different. I used teh same hubs with different endcaps on different bikes.
HTH
Posted : 08/01/2018 10:35 am
Alas, spesh have confirmed it can’t be converted, for anyone that has the same issue in future.
Fatsno it is then...
Posted : 10/01/2018 5:44 pm
Specialized hubs likely use a generic hub design made by the likes of Formula. Do the end caps pull-off or unscrew and you can access the bearings - chances are that if its a standard bearing with a 17mm bore then you might be able to find a find an adapter - just because Specialized don't list it, doesn't mean it doesn't exist. I know people have use the Hope caps on other makes of hub.
Posted : 10/01/2018 8:38 pm
Cheers, looks like they do unscrew, I just don’t have the requisite spanners to unscrew them...
Off to the lbs I go...
Posted : 10/01/2018 9:17 pm
