Specialized Camber ...
[Closed] Specialized Camber 12mm142 axles.
Hi Guys,
I did a quick search and couldn't see anything. I've just got a specialized camber and it comes with a 12 axle the bolts through into the frame, much like a fork.
I've got a pro 2 wheel which isnt this standard. I've found it seems to be called X12 but then that looks like its bolts into the axle and not bolt through.
You also don't seem to get any bearings with this axles which I'm guessing will need a larger diameter centre :S
Anyone got any previous experience?
Cheers,
Tim.
I'll try ringing Hope on monday for advice if no one knows and post the outcome.
Posted : 02/10/2011 10:25 am
Spoken with hope. A standard 12mm axle has bolts left and right. the 142X12 is the bolt through system so that axle can be ordered. No need to change bearings as they stay the same size too.
Posted : 06/10/2011 12:06 am
