Historically I've always run SPDs and I feel more secure over technical stuff and generally feel more comfortable on them. Recently I've been riding more on flats to practice some of the things I was taught on a couple of skills courses: manuals, wheelies, bunnyhops (failing so far on that one). I'm also trying to get comfortable with flats on drops.
I've only done 3-4 rides and I'm getting more used to the flats but still feel damn insecure and am riding a lot slower/less relaxed with them. Cos they're bigger I'm also getting a lot more pedal/ground/tree stump contact. On the other hand I feel I can better push the wheels into the ground when I need grip.
But when I ride SPDs after riding flats the confidence boost I get from feeling secure again is definitely a winner. So, what's the best way forward?
1. Ride flats just for skills practice but SPDs for proper riding?
2. Mix up flats and SPDs from one ride to the next just like some people mix up hardtail and FS so you learn proper technique on the one that's harder to ride which then means you ride better overall
3. Keep riding flats on most rides and put up with the insecurity/contact till I get more comfortable with them?
Or is it really just horses for courses?
Any views from them who use both?
Ta
while your at it do you want to solve the "What Tyre" question too!!
if your coping with both keep working with both don't feel there is an answer
They both have + and - points. It all comes down to what you prefer. I prefer flat so thats what my bikes have.
I used SPDs for ages, but decided to try out flats to prepare for an alps trip and I instantly really liked it. Only downside for me was you def notice the difference on tricky climbs.
I feel more planted on the bike on flats, and better able to shift my weight around. Personally I would stick with the flats for while until you get used to them - I think you learn bad habits for jumping/drops on SPDs.
in time you will adapt your spd technique over to flats.
Like everything else,there is no best. I use spuds. They give me confidence over technical terrain and I feel part of the bike,Also flats are so ugly,especially on XC bikes.
I have no interest in improving my skills. I just pedal.
like alot of people i think - although according to the survey not many on here, i use both.
SPD's - for all xc and most downhill - I would only use flats on a very tight, or smooth but jumpy dh run.
Flats - messing about in woods jumping over logs etc. Dirt jumping, just playing around...
It takes a whilke but you do adapt to flats.
try pointing your heels down a bit when riding, and up when trying to bunny hop (i find it easier to hop with flats...)
technical terrain is where flats excel!
There was a time when i used spd pedals no matter what , then I had a bad fall on my fs big bike(6" both ends) that wouldn't have been quite so bad if I hadn't been still attached to the bike ๐ , since then I changed to flats on that bike and kept the spd's for the xc hardtail.
I'm comfortable swapping between either type.
SPD
difficult to clip in on a hill start
good ground clearance
good pedalling efficiency
feet don't shake off on bumpy bits
light weight
SPD with a cage
better for hill starts
poor ground clearance
Flat
best for hill starts
good for learning to ride properly and getting experimental
good if you ride switchbacks and want to dab tight corners
no good for the pedally bits
lol
I mostly agree with that list, but I'm pretty sure my SS flat pedals have at least as good ground clearance as my xtr spds do, maybe better. They're pretty thin.
Also not sure about 'your feet not shaking off on bumpy bits with SPDs either - I have come unclipped occasionally at some very inopportune moments, even with the tension turned up pretty tight.
Abductee- What is riding properly? how do you do it?
oh- one bad thing abou flats- they hate shins...
I would say it's shifting your weight around properly to control the bike rather than relying on yanking the bike around by the pedals.
As abtuctee says.
One more for flats - if you're going to get drunk and cycle back, SPD's might be difficult to unclip.
i AM ENJOYING FLATS (2 WEEKS IN) and love them on down hills as you can chage foot position easily and shift your weight around.
Downsides are feet coming away on rough stuff and it being harder to climb on techy stuff
Another one for flats is that you don't need special shoes to ride your bike. SPDs are for road bikes ๐
its not harder its technique.
rubbish. Its not a better technique. Just a different one. ALot of people who ride flats, cant ride spd's...
WHy do you think that is then?
Yes that was wrong. Pedalling proper circles is best done with SPDs but manoeuvring the bike with flats?
It is horses for courses in my opinion.
Lyons - When I have learned to ride properly I will let you know the details. My shins are bleeding right now so I clearly have not learned yet.
ALL riding is the same technique
with flats you get away with nothing unless its done correctly so, its not rubbish
jedi on a rough/rocky climb - how do you stop your feet coming away from the pedals? It feels (IMO) like you are pushing the bike into teh ground - hence teh terrain feels rougher (genuine question btw)
Hah - abductee - my shins arent bleeding, just my calf today... but it reminded me of the perils, so i think i'll be wearing my knee AND shin pads in the future...
I do kind of agree though... I think i ride like i'm using flats when using spd's anyway. After about 4 years of just spd's, it only took a few hours to adjust back to flats.
But at the same time, i do like being able to move the back round a little bit lazilly with spd'S
Im talking rubbish now and contradicting myself... ๐
rolf, heals down and weight shifts
the heels down thing works dead well on down hills, will give it a go. The weight shifting is not my strong point - needs work
look at hwere you want to be not where your riding
spd s are more efficient and put less stress on your foot, typically you wear stiffer soled shoes with. For out and out pedalling they are better- more efficient are likely more comfortable.
Flats allow you to move about more, dab and start riding more easily, as well as bail...
Once the terrain starts heading all downhill then look to flats, if uphill or all day rides, look to spds.
Mix and match here. Spds better for ultimate power transfer and faster over rocky stuff in a straight line. Being locked into the bike also means you have to commit fully to a move, rather than being able to dab part way through. Flats much better for serious technical stuff, twisty trails and jumps/drops. They make you *ride* the bike rather than simply point and hang on.
Best way to learn either is to stick with the one you like least. Its taken me a long time to get used to flats, but I'm now pretty happy riding most things on either.
I changed from SPD's to Flats about a year ago and, although sometimes tempted, haven't gone (and prolly wont go) back to SPD's.
Flats:
Forces better riding technique and body positioning if you are not/ever going to be a riding God. My riding has improved 500% since changing to flats. If I'm not relaxed, keeping my heels back, compressing at the right time etc, my feet come off the pedals. Nowt like that to start learning how to get it right!
Seemingly less injury risk as I mostly bounce well clear of the bike now if I have a big off, or bail sensibly before that happens.
Easier to restart.
Don't need SPD shoes.
Look better (IMO)
Oh and feet do stay on over the rough stuff/jumps/drops once you get the technique.
SPD's:
Far superior for climbing (particularly technical).
Makes speed hopping/riding rough stuff easy because you can pull the bike up
Foot always in the same position on the pedal (probably the only thing now that makes me think about changing back is getting frustrated by not finding the 'sweet spot' on flat pedals and having to keep repositioning my feet until I do. You'd think by now it'll be second nature).
last year i was living in the alps and used spuds about 95% of the time. since then i've moved to somewhere...er... less rugged. i now use almost exclusivley flats.
i umm'd and rrrr'd as to whether i'd stick with flats or use SPDs for my alpencross.
in the end i plumped for Spuds. as said above; better for climbing, long distances, techy uphill sections and, as memtioned by bunny girl, more control hopping obstacles at speed.
not having the option of not being able to move your foot around becomes tedious after a while; made worse if the cleats aren't angled correctly.
the stiffer sole paired with the fact you're foot is fixed to the bike does send more vibration from the ground through to your legs.
i prefer riding flats but wouldn't be put off attempting anything because i'm using spuds. i don't find it takes any longer to bail using spuds than flats.
I'd only use flats now if I was doing dirt jumping. I can't wheelie more than a few yards so SPD's are fine for me there and i can bunnyhop with either. One thing that did happen to me was when I used flats was my feet were permitted to take their natural position which is pointing outwards. The SPD's restrict that to a degree and on flats my feet point out that much that I was putting all the load through the inside tendon (or something), which totally screwed my knees up. Back to SPD's and they're fine. This was over long rides on a very regular basis though.
spd's for any distance, flats for ****n aboot with.
Bollocks. I can happy ride for miles and miles on flats. And don't find techy climbs any more difficult on flats. Like I said at the start, its all about personal preference. I used SPDs for 7 years, moved to flats to try 'em out and just prefered them. I dunny like the shin smacking moments though...
coogan - over what distances are we talking ?
where distance is over 30 miles, i prefer the support of SPD's and a stiffer sole.
unless of course your rides never exceed 30 miles ?
Ridden over 30 miles on flats. It was fine. You prefer the support, thats cool. I just prefer flats, which is also cool.
Well i'm quite happy with [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=4516 ]these[/url]
at the moment. For me at least, they provide a nice compromise offering some of the benefits of both flats and SPDs.
Which one would Geoff Capes use?
Exactly!
Flats knacker my knees If I ride any distance as do Shimano SPD so I use Time Alium on the XC bike and keep the flats for the 24" mucking about in the woods and going to the chippie bike.
Last time I looked DH racers seem to be split 50/50 flats/clipped so it just seems to be what you like.
As for this clipped ruins your techique load of bollocks I can bunnyhop the same log clipped or flat its your body english that lets you jump what your standing on has little to do with it IMO
My ankle was gubbed and spds hurt me knee - moved to flats(after 13yrs biking) and I quite like 'em. Not really much different in general use better for descending though and on the way up only difference is trickier to pull up over obstacles, though you get round it after a while.
I am hardcore though.
Fouck I must have been doing something wrong then because spd never bothered me in thoses alpine switchback...
But hey it's true flat are sooooo much beter for dhing...
Look only rubbish people like steve peat, nicola vouilloz, fabien barel and anne caroline chausson uses them ;).
What would Steve Peat know hes only a plumber and Vouilloz is a taxi driver ๐
Just put SPDs on my Enduro for the first time in about 6 months, and really liked it. I've been on SPDs on my singlespeed throughout, and have noticed my pedalling technique get a lot smoother.
Putting this onto my other bike made me realise just how much more efficient SPDs are and how reliant I am on the upstroke that you just can't get to the same degree on flats.
That said, I'll stick to flats on the techy descents.
I never understand people who can't unclip to dab or clip in on a restart on hills - its really easy. Just needs practice with the right technique
SPDs do make you lazy about foot position tho. I learnt to bunny hop on flats and its led to a huge improvement in my riding but I so prefer spds for the greater efficiency when peddling.
Flats for pretty much everything here including 30 mile plus XC rides.
However, on high speed technical stuff or tracks with massive braking bumps, i.e in the Alps, I prefer to be clipped in!
I've gone from flats to SPD's at the start of this year.
I ride with the little normal ones on my HT and the caged styles ones on my 130mm f/r FS, there are times when I feel a bit dodgy on descents on the FS but having the caged ones allows me to unclip and ride the cages.
I do feel my pedalling technique has improved, but you do notice that you tend to drag the back of the bike up out of laziness more than anything.
