Some tyre recommend...
[Closed] Some tyre recommendations if you please...
Hi guys
Need some advice/recommendations on tyres for the HT. I ran Ignitors when it was dry last year and they were fine. Threw some Geax Daturas on when the weather was awful and they were great. Not only for grip and dealing with the conditions but due to the deeper side wall, seemed a lot more comfortable and able to deal with bumpy, rooty, rocky terrain. Basically a more comfortable more composed ride. The only problem with them is they are noticeably draggy in the dry so switched back to Ignitors.
Now I find the Ignitors harsher, less comfy and all in all less capable of dealing with the same terrain as the Geax and I beleive it has much to do with the difference in sidewall height with the Geax being a lot deeper.
So... can anyone recommend a good dry weather tyre but that has a deeper side wall than the Ingnitor or comparable XC tyres?
Running the Ignitors with tubes at 40 psi front and rear if that would make a difference.
Cheers!
Posted : 17/04/2013 11:00 am
 jimw
I run my ignitors at 33/35psi. Might be worth trying a reduced pressure.
I have found Panaracer Rampage Sport 2.35's work well on my long travel hardtail in summer round here, but they are heavier.
Posted : 17/04/2013 11:07 am
Cheers jimw.
I will give them a go at a lower pressure and see how they are. I must admit I haven't ever tried them lower than 40psi.
Anything else I should consider peeps?
ta 🙂
Posted : 17/04/2013 11:54 am
I swear by a Maxxis Ikon in a 2.2 on the rear - wire bead run tubeless perfectly too.
Decent sidewalls, good volume and fast rolling. Cheap too at about £22.
Maybe then look at something like a Spesh Butcher Control 2.3 or Purgatory 2.3 up front?
Hope that helps.
Posted : 17/04/2013 12:03 pm
Just today received a pair of Spesh Purgatory 2.3's. Been using Rampage 2.3's which are pretty sketchy in the wet. Great for rocky techy stuff though
Posted : 17/04/2013 12:20 pm
Maxxis Ikon +1
Posted : 17/04/2013 12:24 pm
Ardent for a bit more volume?
Posted : 17/04/2013 12:40 pm
Thanks for suggestion chaps. Sounds like an Ikon on the rear and Ardent on the front might be the way forward. Have to have matching makes albeit different models 😳
Will drop the tyre pressures on the Ignitors and see whats what but I think bigger volume tyres is the way forward.
Any more suggestions welcome!
Posted : 17/04/2013 12:57 pm
someone (not me) is selling an Ardent on classifieds - was tempted myself !
Posted : 17/04/2013 12:59 pm
Cheers ianc. 29 whole inches though... 3 more than I need 🙂
Posted : 17/04/2013 1:07 pm
